Feedback and Support
F&S Forum Contacting joratcliffe
  • Announcements
  • Site Updates
  • FAQ
  • Suggestions
  • Support Forum
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 24 Nov 2026 23:16:08 GMT ETag: "0x8DF300D76CC4AFB" Set-Cookie: .te.csrf=IJo8WIjp7KaHVKqVZ7F-6egIMP6X9WRpBG7vcEwv-FY; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_1tf7%2bqwzGLAVTQFeT1%2bKZxx8J4k%2ft3Zm4obfwhcreBduLCAKW03V%2faK0fNNGtN%2bZH7Qlo1TlMM0myrqyNmSsolv9zDmxsUyhhgHYI%2fXKHbT6tuhtlNM%2fw3SXJlrNrEyjCCVFys4CHu9ozXdSwCsJ16o7SIZfZpmd1sTtaTeZjTKBWUB0UnojPUrWiE8kKzyF9ylDs2U57pns9HlQq7EXiDr0imU4HG1LY2IHkF0zk6OVbz8VgjMARFLEnfo2ts%2fRePKQvwplcqRi9w0aLXsGdw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=43 Server-Timing: origin; dur=43 Server-Timing: ak_p; desc="1795562168537_34604952_732630016_8547_6667_6_5_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Subscribers 18 subscribers
  • Views 66 views
  • Permissions
misaz
misaz 4 months ago
Hi, If I remember correctly, in history there were option to contact Element14 community staff by private message without need to ask for firendship or whatever approval process. But I want to contact joratcliffe and can't. Could you please check that he is properly marked as E14 staff?
  • cstanton
    cstanton 4 months ago +2 verified
    Hi misaz , gordonmx , Thanks for reporting the problem messaging Jordan, I've investigated this and I believe I've found the cause of the problem and implemented a fix. You should now be able to message…
  • misaz
    0 misaz 4 months ago in reply to cstanton
    Thanks. Now I can write him freely.
  • cstanton
    +2 cstanton 4 months ago
    You should now be able to message back and forth. Do let us know if any further problems arise.
  • gordonmx
    0 gordonmx 4 months ago
    Misaz,
    I also have been trying to reply to a message from Jo and thought I needed to "connect" by requesting to become a "friend".  There is a button to make a friend request, which I pressed, but haven't had a reply yet.  However, I later revisited Jo original email and notice below the message was a space to reply.
    gordonmx
