Feedback and Support
F&S Forum How to call into the void
  • Announcements
  • Site Updates
  • FAQ
  • Suggestions
  • Support Forum
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 24 Nov 2026 23:17:12 GMT ETag: "0x8DF300D76CC4AFB" Set-Cookie: .te.csrf=HUDCDDrbnM8xN3rwmz-ujLRJag3B9jrGkf8qvF-QQzQ; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_Nn7K%2bTR7nK3CPLhx2MklDi1sh8qbn2rNfX2m7PVGpuQG6igDYSl8B3pgeHNY%2fFAIVhKqn2t9fadfa8kLhZ3VNZy268YSVHziHPFTSqcG%2f7odGQ9I3rwsBO7sEpEOpwOBdQohErt%2fIIRtY5C8%2bjYLa0mUU2lpxEl7QfsVyQRpuv3S%2bV8KRuG%2fovTg93epQb76vLunphKnNvfoYZf5cTDkBu90DBs%2fJhx9MNWkQOtfv0MAkFUxu9R%2bgWIsTytLiCcM82SE4uS6Rjl4%2bdaJDrwlgg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=45 Server-Timing: ak_p; desc="1795562232566_34604952_732674142_7686_6191_6_5_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 18 subscribers
  • Views 29 views
  • Permissions
colporteur
colporteur 3 days ago
I received this message early Saturday morning. What I pondered is how do I report the problem if the problem persisted.
I moved on after 15 minutes of failed attempts. It was resolved some four hours later when I revisited the site. IS there a 1-800-help line for my E14Community fix?
  • Reply
  • colporteur
    0 colporteur 1 day ago in reply to Dudley
    Welcome to help if I can. I have some sharpness but I pale in comparison to the edge many of the members have.
    I don't think this extensions are paranioa but two password manager might put me close.
    I used both chrome and firefox to arrive at the same messages. The extensions are on the chrome not on the firefox.
    • Reply
  • Dudley
    0 Dudley 1 day ago
    Hello colporteur ! Been a while Two hearts
    Looks like you've fallen foul of our bot protection, but it isn't immediately apparent why. I seem to recall you have a software background - would you be running any paranoia style extensions in your browser such as noscript or something else that masks your presence in some way? Not saying there's anything wrong with that, I'm just trying to understand what is going on here (as you definitely win the weirdest reason for getting a temporary block - an "Interdictionary aggregated anomaly"...)
    If you are running any extensions, any chance you could send me which extensions you're using and I'll try to reproduce that in house.
    As for how to reach out to us should you ever have a problem, there is always our discord server. https://discord.gg/nTqUQEX5gw
    Dudley
    • Reply
