Feedback and Support
Site Announcements and Status Resolved: Azure Server Maintenance - 21st July 2022
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Mon, 23 Mar 2026 04:45:48 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=1QR9TaaCo9ruLHSOGJU494js_7k4lEPJL5lCKzbXaNo; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_aFbFWuJbAKVt63VbdlDEfycfCxHnqptYUg8ma%2fHQhatjYCH2lztY28BBu%2bXQM1LarKDeBhrb2Dv4tPuSnT2FwoBcDd2bL1MfyawOsAGLzvTnCxtLaTOaGw%2baMp8dagT4AaDHOJpBl1QwBsBsyRXQHs5HRx%2fDIJ%2fbqVCnRnZQaQtZ6S%2fO4G3pLZ759qDEdG05YoZNSm3GXm5BkFYqt79HqF245th3orDuzYDlPbpBGeZwKh6GtrVki68TK6YLaTgKGN4KGzKRaiw9k7KMqEe1bQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=47 Server-Timing: ak_p; desc="1774241148507_34604952_2680908612_7833_8448_6_9_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 745 views
  • azure
  • sql database
  • database
  • server maintenance
cstanton
cstanton over 3 years ago
"Impact Statement: Starting at 03:47 UTC on 21 Jul 2022, customers using SQL Database in West Europe may experience issues accessing services. New connections to databases in this region may result in an error or timeout. Existing connections remain available to accept new requests, however if those connections are terminated then re-established, they may fail. Our SQL engineers identified a configuration change on the metadata drop operation which has caused the overall issue. Current Status: The majority of impacted customers should now see service recovery. We are continuing to validate full mitigation. A further update will be provided in 60 mins, or as events warrant."
https://status.azure.com/en-gb/status
  • cstanton
    This maintenance window should now be resolved.
