Feedback and Support
Site Announcements and Status Unintended Site Downtime: 4th of September
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 27 Mar 2026 01:55:34 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=P91kYtd4hKf9bXevZdjkm2_TGngul3d1MCvVzsci-b0; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_cXOlFQ%2bjDZ2%2fXNWgz5HrOp%2bEPESp4HIKWTUhOAJJJDLXQX0QDLtUks3zY7U2bi0T%2fBMlfVlZVuIplHQTrqYZtbRtsOdInkkyDJ%2f4znW%2fWyrfQJopnL8WkKVFuxgPI8mzRLld1%2flq8O%2fqjGlc77nndsSZsG3shW%2f%2bt9KYg1OBBSTE0oBvtUEXNJacCEliz4GI4nmx03vK0B4XuqKGt%2b8tdYdmwbQOQQx%2fGLuJYe9x6S8zPF08wkJCXdkhyk6%2bDcE0VJQ3hhn0HcnNf0G0w4G47g%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=42 Server-Timing: ak_p; desc="1774576534238_34604952_3846790055_7290_6593_5_6_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 375 views
  • ddos
  • site downtime
  • bot traffic
cstanton
cstanton over 3 years ago
The element14 Community development team and site administrators are investigating a site outage that occurred over the weekend.
While usually we point the finger at the backend platform, vendor, or otherwise, it appears this outage was caused by a purposeful high amount of traffic from various sources.
As an insight into this, you can see where the page views per second skyrocketed to the element14 Community in this graph:
This is particularly unusual behavior, and it appears this may be happening periodically which is causing the website issues.
The appropriate teams are investigating on how to protect against this in future.
Thanks to our server admin that responded to the outage on Sunday and brought the site back online.
