Feedback and Support
Site Announcements and Status Site Maintenance: 13th Jan 2023
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Tue, 24 Mar 2026 09:50:05 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=BBe0VBqdErjad2UGmTSFxOkhuzPU3L2zrOCkz0WiyD8; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_0k27pZUEwlSnwBMwNaQRYhPkFRlkRp6aBxP6uiHjwIbgK4y1iBhobt5gK2zXHMGKfSL5fvyElpdIrBooKIBxRrSs5U5Pac78iOCDZQxEdqS9V9zGl%2f2vOETuyxBsN%2fbgy8eKO46AciI1vH0avujwlzU37wmJSW2Q8ehZCruPeV6RjisaJKvZ7MQnMYepUpA9PFPUlt0IDj7vj9VhAA7d8JTOr0wTMwCA3nXn6OxxfrDvJMo6kf1daIlqiG9eR2CsyxMvPpvuC4LNF%2f2LaiYQ5g%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=33 Server-Timing: origin; dur=43 Server-Timing: ak_p; desc="1774345805468_34604952_3050962772_7626_6521_5_6_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 585 views
  • site maintenance
cstanton
cstanton over 3 years ago
The element14 Community will be down for maintenance from 5:00PM CST today. That will be from 11:00PM GMT
It's predicted that testing and maintenance will take approximately 5 hours from this time.
This is to push fixes intended to address the site downtimes that we've recently been experiencing and problems with website extensions.
As usual with our site updates, the website will be down and then it will be expected to be slow for the hours after it comes back up as the development team performs tests and the website reindexes itself.
The server admin team will be monitoring the site for activity and the site may go down further in a controlled manner to revert any changes if necessary.
