Feedback and Support
Site Announcements and Status Resolved: Unable to set an answer as 'Suggested Answer' or 'Verified Answer'
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 13 Mar 2026 14:31:29 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=rpRusKTFnGDkf8uP8qXIW7I1tjn08EGzP9C8tMIBHcQ; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_0vZLW7ir%2fbfo6NN%2f4dUe%2b2VjZgj2pBaSFdVjZ6zf1ejPUoqLgAhbQ8YISmA0NOaE5ibtiV5mbmJTl3iklzd0vSz1NrTtI6pTsA13yC8D3WQTsy8zlvIKUfXcEdmB2bwFKvWwQrCO3wXIHiZMBFP6FN%2fFV9nvw51RisyE23bAeREu4FvhpD%2fCQM7dxuMwSgu3%2b%2fZpKJfMC6ODHYDrBA3pRGJa7z529uDbn2iRYa3mVF%2b%2bJxGsz30o1bMEApD7ThSvoqLXV6mfkYuMKpqejIkM5Q%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=36 Server-Timing: origin; dur=77 Server-Timing: ak_p; desc="1773412289419_34864915_382960844_11187_5882_5_10_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 717 views
  • site issue
  • known problem
cstanton
cstanton over 3 years ago
We're aware of a problem affecting certain forums on the Community where it will not allow administrators to set the threads in that forum, to be of a 'Question and Answer' type.
This means you cannot mark a reply as a 'suggested' or 'verified' answer.
We have escalated this with the platform vendor and do not have a timeline of resolution at present.
  • cstanton
    cstanton over 2 years ago
    This should be resolved when we finally update to 12.1.4 in the coming months.
  • cstanton
    cstanton over 2 years ago in reply to cstanton
    This is resolved, however we need to set some forums to permit Question and Answer thread types for this to be enacted and this will be done gradually.
