Feedback and Support
Site Announcements and Status Resolved: Unscheduled downtime and site restart
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Thu, 15 Jan 2026 12:45:11 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=thKqXOH5NLxtBzIxzRoiqODxDx6g2wvTxv4KmmtW_GA; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_nAwDaClJmhOHVQRajtiNKdlhSeAJFL2Bw3AjMsN8ObZAbiU%2fk0d%2feb9cmP1bEZdoFzHMbbgG%2bopmrH6%2fu9Xp%2b%2bpgMsYdWu%2fXR%2fAJ%2fkRMaCNEknHEpasU96hNWKM3QzYXPEZpRKwrkicNeb5Q%2fCDma%2fJwoixN%2feDbLnuLstsZu5ApWj%2bzHH2yVH%2ff%2bwKAVRUJF2VtPFxy2CwU35Ll4Cm4pAkn4Se%2fchpu0jsupUa%2bx0E3B8P65CkVczJCCjuo98nCeYhkw0kF8SEzMeSwaNGprw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=49 Server-Timing: ak_p; desc="1768481111787_34604941_1511262667_7951_4884_5_7_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 291 views
  • site issue
  • site downtime
cstanton
cstanton over 2 years ago
At around 3pm UK time on the 13th of March the site became unresponsive and returned about 10 minutes later. The site then went down as the server stack was restarted by the server administration team.
We suspect this outage was caused by a bug with custom site administration tools and shouldn't be typical behavior.
