Feedback and Support
Site Announcements and Status Resolved: Embedded Achievements show "Invalid GUID"
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sun, 15 Mar 2026 15:50:34 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=iETNS1qBerlD8TBxJW7LemCYs-jtIVC7j4JdvFC2QJc; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_yCIYpxSEQYDMVKbqB7QaLk2b2qMo8HYZZViFgAPc4XoATbxj1LNdvH6ejaK6AJ%2bchXhDEDHBmoKrwvGQetG88L0Ktskis14vz4GVJKCrvG9PtkK0HwkRXZ7KuDEp3IFZGc0Gh%2fAbXIR1cQIkxeWZ8oScseLpmj%2ffoAJok8nVkO6IwEi5MXOZNCBEw6yGp4tMRLPn48nWJjafFLcJ%2f77%2bJPfe8LsKow%2f9bCkFkPSRY2V%2b9ZU6m16hr2Q%2biDcx1Fs8JmjhJyRjg%2fp8X8E1WpisxQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=47 Server-Timing: ak_p; desc="1773589834262_34604952_55730971_7902_6167_6_7_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 374 views
  • achievements
cstanton
cstanton over 2 years ago
After the development release on the 2nd of May, locations where achievements are embedded into content will display "Invalid GUID".
This is because of a change in how achievements are embedded into content, from using their unique identifier to a 'template' that allows administrators to search for the achievement. Unfortunately a mishap with the logic meant that it ignores where a GUID was put in the field, and results in this error.
There should be no issue with gaining the achievement, a hotfix is being worked upon, else it will be fixed in the next development website release.
  • cstanton
    This should now be resolved.
