Feedback and Support
Site Announcements and Status Unplanned Maintenance: Quizzes, RoadTest Applications and Design Challenge Applications Part 2
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 27 Mar 2026 03:34:47 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=wp0wXq8soeFtbomhH018WYKFMW7vlmfn2oERwIfJGWE; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_J9rQYyUn%2bT6daDGUxLfMtPamfF89KqgdcIdmCGrixP7VoivBCKK2%2bhJEmz%2bYdtPbdfWNAm3%2bdL1wKP1Qf80%2btk0colWNrbROajf554BkVcinJhIWS0CAOostNYjiOmjD%2fKRJnNtEyMrQZWiIANkEZqmlI3P1T6uulTrrjmARtBWOnbM6TEZoMKWF6wHiCvOoNgtofgNzkhwn%2fg%2bqtWqHD%2fl5BKEyPjqE12Q8Fj3hL4pIvIodLw1dthSF7OcDVfE%2fsMk1%2bx3HdzzXhT2PVgdFvA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=42 Server-Timing: ak_p; desc="1774582487873_34604952_3871512204_7377_6504_5_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 443 views
  • site maintenance
oadesida
oadesida over 2 years ago
The server that is used for quizzes, roadtest applications and design challenge applications will be down for unscheduled maintenance this afternoon. This should only take 10 minutes, but may take longer if there's unforeseen work that needs to be done.
The development team apologizes for the short notice.
  • cstanton
    cstanton over 2 years ago
    This was successfully completed.
