Feedback and Support
Site Announcements and Status Known Issue: Sometimes Completing a Quiz Will Not Give You Points
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 13 Mar 2026 17:02:32 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=JAo4gClDszHHk9hefJwqt_gv4JjMkjeLPWk6RfMsWHU; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_G8jCSC3WBg9GL2ytBTCG35N6Cx1rd8mm7yJ5snEdpC5YwAH%2b6WbcScjflcgYNGbaSFkmz9WpYBT1zQOftADLYNwQm%2fZazy4wICz7ECAHgUolfeDl7CbiEJ4Q1%2feMliArzvL14jKrNgfNkmKK6YdQvi7IzUy1qU6ZLs83S0riICwLY6EDP1Tog43Ud67ENrknzV1Ye%2bKDmJsdjcJuUcVyzYiikAY%2f8RrL%2fEYnO2WdtM3BshUWMba5Evztbmn57nPwoWemX39PmfYZ%2bgbhFPp5cQ%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=44 Server-Timing: origin; dur=44 Server-Timing: ak_p; desc="1773421352049_34864915_388566575_8771_5780_20_10_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 456 views
  • gamification
  • points
  • quiz
  • achievements
cstanton
cstanton over 2 years ago
Unfortunately this is a problem that has been with us since at least October 2022, sometimes if you fulfil a quiz you will gain the achievement, but not the points.
The development team are looking into it.
  • cstanton
    cstanton over 2 years ago +1
    We have an update from the platform provider Verint on this issue. It is because there is a setting within the site platform to only award points on content that is <x> years old. Where <x> is a defined…
  • cstanton
    It is because there is a setting within the site platform to only award points on content that is <x> years old. Where <x> is a defined value. By default, this value is '2'. A lot of our quizzes on the site, particularly the 'essentials' range, are older than 2 years, so it does not give points to members.
    We are currently testing setting this to a larger value, of 10 or 15 years, since the element14 Community is at least 12 years old.
