Feedback and Support
Site Announcements and Status Known Issue: Downloading eBooks, Applying for Design Challenge / RoadTest and Quizzes
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sat, 28 Mar 2026 00:07:35 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=RhMkjA51QUktiM0z_PJkuhxaj0Q1j29wHEiwp8t094M; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_1x3dPpqDHyUrULvxyGFpCueMkodbEzKWAHNwV65U5Gx6K4YagSJX1aHs%2fujGDUlBTXSrE0wMvGEtjsY%2bq%2boLYO7cm6pM7qVAZsJe2tO9BOD2D4m0cvsLqBrVorneq6N19uvRu1Blgain2EMHylOc41ATTTvboVwGjJX%2fmMbJy%2bK8eWwWf8EBjrw8szh9gg%2fOFARh%2b78Zz5WglqKqjOLU%2fK26%2b6QndLAHNPUyLEQ8EofZrrGAgq0Sd7WULi5FdNWkt8l%2bJETFbEPTT2i4iz2Zrg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=37 Server-Timing: origin; dur=48 Server-Timing: ak_p; desc="1774656454913_34864915_382867227_8531_5226_6_7_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 278 views
  • RoadTest
  • design challenge
  • quiz
  • known problem
  • ebook
cstanton
cstanton over 2 years ago
There's a known problem that affects receiving achievements for quizzes, being able to mark answers correct and highlight incorrect answers for quizzes, attempting to download ebooks and discovering that the form to do so is blank, or claims that you need to re-register for an account, or re-login, and similar when applying for a Design Challenge or RoadTest.
The issue appears to be related to caching and presenting JavaScript to the user. The admin/dev ops team are having difficulty repeatedly recreating this scenario to narrow it down, however, we're aware that members are experiencing this issue repeatedly.
You may be able to work around this by clearing your browser cache, using a private tab, incognito mode, changing web browsers, and making sure that you're not blocking JavaScript.
The development team has been aware of this issue since at least July 2023 and is still looking into it.
