Feedback and Support
Site Announcements and Status Resolved: Needing to Register before Downloading ebook
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 13 Mar 2026 21:41:00 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=74ePkBsCkpoArrw9YseILIOMqWfa5tZOCCVwunlcNUg; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_s2YX5c0Gm0iaJU6ThAZKt7sHNrIUJFWRWrSkT74tkYdMfDZxtroqrcpI5ZwDvyqDXTtIDiaO8EfylUoGWKxuk5NujYYtxqkhCusLAPI0gDiq9e%2bW3Y32a3cFq%2frs5pfhtkXclhShUTMswbg2TlpCKGaqUqh9ERrKhzCX4aug3f2jkXVlFsNVscOuYax2Nf2uE7pqahJCPOVSldBUceEckMgSaDdb2ZGd4S%2fPlUgRtYYW%2fF%2bP59iFL4g1QYzSjKT3Pp0h%2fMA2WKD3AjjOLh95%2bg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=34 Server-Timing: origin; dur=35 Server-Timing: ak_p; desc="1773438060397_34604952_286061660_6833_5378_4_6_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 3 subscribers
  • Views 152 views
  • registration
  • download
  • ebook
cstanton
cstanton 7 months ago
There's currently an issue affecting the ability to download ebooks if you're a new user to the element14 Community.
Our integration with a third party for the form used for ebooks is causing a problem.
If you're new to the element14 Community and do not have an account to login to, when you attempt to download an ebook and register for the element14 Community using the form, you will receive an error and the registration will fail.
The workaround for this at present is to register for the element14 Community here: /user/createuser - then login to the website, and download the ebook.
