Documents ZX2051 AM/FM Radio Receiver Kit Documentation
  • Author Author: shabaz
  • Date Created: 7 Jul 2019 3:17 PM Date Created
  • Last Updated Last Updated: 22 Jun 2021 12:22 PM
  • Views 5086 views
  • Comments 17 comments
The ZX2051 is a low-cost kit to build an AM/FM radio receiver. I thought it could be fun for kids to assemble. The instructions are in Chinese, so the purpose of this blog post was to document any information needed in English (or other languages) to successfully build it.
Any translations, or advice, is welcome, since I cannot do this entirely on my own : )
Original Documentation
Since I don't have the copyright to it, I've saved high-res scans of the ZX2051 documentation on a third party server during the time that collaboration is needed, but will remove the link after it is no longer required to act as the only documentation.
There are low-res copies of it here (might not be readable), which I believe is fair use.
Translation Attempt #1
Google Lens was attempted, with some success and some amusement. It didn't get the translation entirely right I think : )
Another attempt was only slightly better:
One more time..
PCB Layout and Notes
The scan here shows the copper side PCB layout, with some of the important bits highlighted in red.
From what I can tell using Google Lens to do the translation, the quadruple tuning/variable capacitor needs the end with the two wires to be inserted in the red highlighted hole, because one side of it contains the FM capacitors (lower capacitance) but the side with the two wires that insert in one hole, is the AM side (higher capacitance).
Also, T2 is highlighted with a red square. T2 is the metal can with the core that is painted red.
For the electrolytic capacitors, the hatched/shaded side of the circles in the diagram above is the negative end.
To be continued..
More info to follow after this kit has been soldered!
  • fm radio
  • zx2051
  • electronics kit
  • radio
  • am radio
  • electronic kit
    shabaz over 7 years ago in reply to jw0752 +6
    Hi genebren and jw0752 , We managed to solder all the resistors, and some of the ceramics today : ) The 8-year old was trained by showing him how to solder one resistor to scrap PCB, and then he tried…
    genebren over 7 years ago +5
    Shabaz, The translations are quite amusing. Not sure how the 'prisoners' helped with the circuit or why it is necessary to go to a liberal arts school in order to receive the broadcast, or how this effects…
    jw0752 over 7 years ago +5
    Hi Shabaz, My experience has been that there is usually enough information between the bill of materials which has some information in English (part # and Value) and the screen printing on the board to…
    Shabaz,
    The translations are quite amusing.  Not sure how the 'prisoners' helped with the circuit or why it is necessary to go to a  liberal arts school in order to receive the broadcast, or how this effects the tea harvest, but OK, it is very interesting.  It does look like you were getting much closer to an actual translation as you continued to try.
    I wonder if John (jw0752 ) will be able to help, as he has worked with several of the overseas kits, helping with some of the documentation.
    Good luck with this project and have fun with your nephews.
    Gene
    • Vote Up +5 Vote Down
    shabaz over 7 years ago in reply to genebren
    I liked the tautology : )
    genebren over 7 years ago in reply to shabaz
    Ok, and the reference to a vegetarian diet?  No mention of necessary religious beliefs?
    I personally was waiting for Google Lens to tell me who shot JFK : )
