Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11218 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • the-dubster
    Well, today I learned that old test equipment isn't always up to the task you had in mind . . . . . . . .
    Popped down for the yearly visit to the parents and, whilst chatting to my father, we go onto an issue he had had installing a neighbour's electric shower. The old unit had stopped working and, my old man being a sort of builder/plumber type, had said he would fit the replacement.
    An easy job it seemed, as it was like for like, and the installation went without many hitches, unfortunately, when trying to run the shower it completely failed to respond! No heating and no neon on the front.
    My dad had popped back to the suppliers but they said they couldn't refund him, he had to call Triton directly . . . . . . . they are coming out early January . . . .
    As the old unit had stopped, and the new one had failed to start I asked him if it had power, his neon screwdriver had lit up, so he assumed it was all good. I mentioned about switched Live/Neutral circuits and was met with a blank stare.
    'Have you got a voltmeter' I asked, 'yes' he replied, 'it's your old one'. He fetched it for me.
    Now, if memory serves, I purchased that meter in Coventry in about 1980. As you can see, the packaging has seen better days, what you cannot see is the verdigris on the + lead socket and - worse still - the AA battery terminals.
    Well I thought, what's the worst that can happen, it may be almost 40 years old but it seems ok(ish).
    Obviously, before venturing around to the neighbour I decided to test it (of course), so I set it to the AC 250V range, used one probe to depress the earth pin shutter and then popped the probes across the 240V mains . . . . . . . . . .
    Well, the carpet didn't get burned at least, the case didn't fit together quite as well as it used to, the big bright flash that flew out of it was rather impressive, and the smelly smoke that rolled up our collective nostrils certainly didn't smell overly magic anymore.
    As you can see, a nearly 40 year old meter, with pretty thin tracks in the first place, compounded by many years of neglect and corrosion, cannot actually handle 240V any more! Close inspection reveals a few tracks/pads are now absent, and some sections appear to be somewhat shorter and melted.
    The inside of the case is a slightly different shade to the original too.
    So there you go, you wanted a story - you got one, you wanted pictures - you got those too. My dad now has no multimeter, two 13A fuses less than this morning, and no way to test any he has lying around.
    I offered him a replacement meter, he doesn't want one as, in his own words, he doesn't know how to use them . . . . .
    A casual observer would argue that the same applies to me too!!  image
    • Vote Up +6 Vote Down
  • the-dubster
