Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11189 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • majanan
    majanan over 6 years ago
    For me it's got to be  the deadly scalpel... I will use one in a pickle when I forget or lose my wire strippers...
    I can't count the amount of small cuts I've given myself or the frustration at the inability to properly strip wires and cutting through wire insulation where I shouldn't that I have done with a scalpel.
    The worst case was when I blew all the fuses in my  parent's house by wiring up a wall socket with the smallest gash/cut, incredibly hard to see, on the live wire that touched the metal back box that it was all mounted within.
    Fortunately it was just the fuse box and an angry dad for messing it up rather than a fire but super frustrating to find the issue when we had wired about 10 sockets that day!!
    As an aside, I have messed up a fair few PCBs through hasty use of a scalpel :/
    • Vote Up +5 Vote Down
  • the-dubster
    the-dubster over 6 years ago in reply to majanan
    Had a weird snag on the Tornado F3 RHWR (Radar homing warning receiver) System many years ago. The loom that ran along the spine became our prime suspect, and after doing pin-to-pin checks for open circuits we had to release the aircraft back to squadron with the system 'Limited'.
    A month or so later it returned to the shed for the Major Maintenance, we passed on what we had done and suggested core-to-screen checks were carried out for shorts. Lo and behold, there was one cable in the loom that was exhibiting this very issue.
    Out came the Time Domain Reflectometer (screen and earth cable works very similarly to coax to a TDR) and we found the exact spot the loom was damaged. (You can see transitions thru bulkhead connectors on the TDR trace, and follow them on the wiring diagrams).
    The loom was popped open and the culprit found - a beautiful slice through the outer insulation, the screen and inner insulation, with a few stray strands of screen touching the inner core . . . . . .
    The culprit? The loom is knotted with lacing cord every few inches, and some deft folks were able to invert a scalpel blade between the individual wires in the loom and slice the lacing cord without causing damage.
    The muppet who had done this one however had decided to saw straight across the loom at 90 degrees - he cut the lacing cord, but that unfortunately wasn't all.
    We're right back to accidents (many) that I have had with scalpels, and your examples . . . . . . .scalpels are probably the most useful and, in equal measure, the worst tools to use for electronics . . . . . .
  • the-dubster
