Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11211 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • danielw
    danielw over 6 years ago
    Teeth are not wire strippers,  they really aren't and they aren't the proper tool for splitting lego pieces either!
    I was in my 30's when I found out there was a proper tool for splitting lego!
    Thankfully for my smile I found out about proper wire strippers at a much earlier age after a brief dabble with using a sharp kitchen knife which landed me in trouble with my mum.
    Dan.
    • Vote Up +7 Vote Down
  • danielw
    Dan.
    dougw over 6 years ago in reply to danielw
    Now that you mention it … when it is fingernails versus Lego …. Lego wins.
    Fingernails as prybars  …. great … until they fail.
    Fingernails as chisels … maybe .. but it is a good thing they grow back because they will be erased in short order.
    Fingernails as scrapers …. sure …. but choose wisely.
    Fingernails as wire strippers …. we all try this …. with pretty low success rates.
    Fingernails as label removers … good luck with that
    Fingernails as a knife ….. don't hold your breath
    Fingernails to remove scratch and win …. prepare for disappointment
    Fingernails as screw drivers …. fail.
    Fingernails as soldering iron tip cleaners …. no …. just no.
    When it is fingernails as thermal insulators to pick up hot objects ... it may work, but sooner or later you will regret the choice, most likely sooner.
    Thinking about it ... fingernails are likely the tool that have been the most often damaged through improper use. Throughout history, even going all the way back to before other tools were ever invented.
    • Vote Up +8 Vote Down
  • arduino420
    arduino420 over 6 years ago in reply to dougw
    Douglas you are SO right!!!! What an eloquent way to respond!image
  • danielw
    danielw over 6 years ago in reply to dougw
    I sort of tried the fingernail as a sort of chisel / pry bar once, and ended up with a splinter broken off under my finger nail...
    Fingernails as splinter storage... Not a pleasant experience in the slightest!
    Dan.
