Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11284 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • Gough Lui
    Gough Lui over 6 years ago
    I'd have to say that the worst tool for an electronics job is probably my index finger.
    When I was younger, just starting out in electronics, I had a passion for building kits. It was supposed to be a gentle way to get yourself acquainted with the art of reading component values, populating boards, soldering, clipping leads, testing, troubleshooting and providing the finishing touches with as little risk and as much convenience as possible.
    The first mistake is a very common one - I was soldering a PCB pin to a board as an attachment point for a wire, as I was instructed to do. Not having a set of helping hands or anything, I shoved the pin into the board, held the pin down with my index finger firmly while gripping the sides of the board with the same hand, and using the other hand grabbed the iron and the solder and began to solder the pin. Needless to say, I immediately grasped the concept of thermal conductivity when I grew a blister right in the middle of my index finger ... making work more painful for about a week.
    I thought I'd learned the lesson, but then, I got caught again when it came to tinning a short piece of wire. As I had a crummy thermally-balanced iron, heating times were a little inconsistent, so I was holding the wire at the insulated end and tinning the stripped end. Needless to say, the insulation eventually gets hot and melts as well ... giving me another burn. Add that to inadvertent soldering-iron contact when I used one without a stand ...
    Many years passed and I became more experienced at soldering. Being burned by the iron became a thing of the past. But just last year, I burned my index finger again. This time, it was a bit of a funny story - I usually hold solder with the left hand, feeding it into the iron on the right. Well, on my bench, I had a scrap of 0.8mm 60/40 solder, and a scrap of 1mm tinned copper wire. Guess which one I grabbed and tried to feed into the iron? I was a bit frustrated as it seemed to be taking forever to melt ... and then the heat got to me! D'oh!
    Sometimes, it's not the iron's fault. I have another habit - namely of testing the temperature of something with my finger. Having built a kit, I got a diode in the wrong direction and it shorted out the supply voltage, crowbaring it down to zero. I was wondering what was taking all that current, so I started touching components to see which ones were hot. Needless to say, I burnt my finger on an 1N4004, which taught me a lesson - perhaps use a less important finger instead ... or get a thermal camera.
    But the finger also has a number of remarkable properties - being conductive and attached to the body, I've gotten zapped by touching things and I've also zapped things (e.g. MOSFET gates) by touching them through ESD. My fingers are dangerous.
    - Gough
    • Vote Up +9 Vote Down
  • ntewinkel
    ntewinkel over 6 years ago in reply to Gough Lui
    Ouch!
    I just learned yesterday (using your method) that the "100" for a heated 3d printer bed is, in fact, Celcius image
    You'd think we would learn by now, eh?
    • Vote Up +5 Vote Down
  • ntewinkel
    Ouch!
