Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11401 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
    These rings are not to symbolize membership in some secret society, they are a simple personal reminder of the responsibilities of being an engineer.
    Being steel, they are very strong and can be used as a tool in all sorts of applications (bottle opener, electrical jumper etc.)
    I had a friend who wore his iron ring while working on a vehicle. He was removing the positive lead from the battery when his ring touched the vehicle body. Current ran through the wrench and through his ring to the chassis. The ring, which is not a great conductor, instantly got red hot and badly burned his finger - it looked like it went right to the bone. He was very experienced with vehicle work and knew the rule that you always remove the negative lead first, just got careless. An accident like this can cause the wrench to weld to the ring and the ring to weld to the vehicle, which makes it hard to stop the heating process. I am not sure if this happened in his case.
    Unfortunately or fortunately I don't have a picture as the wound was horrible to look at. (It eventually healed remarkably well).
    I did snag a couple of internet pictures of what a ring (not an iron ring) can do to a hot dog when shorting a much smaller battery:
    Most people are very careful around high voltage apparatus, but if you wear a ring, you need to be careful around low voltage as well.
    And always take the negative lead of a car battery off first. When jump starting a car put the negative on last and take it off first.
    It may be cool to use a ring as a tool, but it is easy to forget that it can be dangerous. A steel ring is strong enough to take a finger off if it gets caught on something. (I don't really think rings are very dangerous in general, but that makes these unusual cases more poignant.)
    I actually never wear my iron ring, I only put it on to take the picture above .... and I still have all my fingers. image
    • Vote Up +11 Vote Down
  • cstanton
    cstanton over 6 years ago in reply to dougw
    Huh, I never knew about this iron ring symbolism, that's cool!
    Rings can be hazardous in any vocation though, my cousin's husband volunteered as a football coach, and was hooking the netting onto the metal goal, unfortunately it hooked onto his ring and he lost his finger trying to get free.
    I also rarely wear rings...
    • Vote Up +7 Vote Down
  • cstanton
