Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11266 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • TCPMeta
    TCPMeta over 6 years ago
    Dunno if this counts but here are a couple.
    A friend of mine decided to troubleshoot a Ceiling Fan. Instead of using a Meter or non-contact tester he grabbed a Test Light that is used to test 12 volt DC automotive circuits. Gator clip on Neutral and used the probe tip on the Live wire. he said the test light exploded and has a scar on his forehead as a reminder.
    My day to day job is a Low Voltage Tech. I do everything from Security, Networking, Audio, Video and Home Automation. Anyway, the company I work for pre-wires new construction homes and a lot of times we get to install equipment. Had a service call about none of the RG6 Coax cable in the house worked. I get there and took off the wall plate in the Living room and the Cable is just totally destroyed. I was able to re-terminate them and got everything working. I found the guy who trimmed the house and asked him what he used to terminate the Coax and he shows me this.
    I grabbed them from his hand and tossed them into the retention pound.
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to Gough Lui
    Gough Luiimage
    I FEEL YOUR PAIN!!
  • dkohn67
    dkohn67 over 6 years ago
    Probably shouldn’t use an impact wrench to attached a low voltage wire to a circuit board. Just sayin...
  • danvel
    danvel over 6 years ago
    We're building a humanoid robot in my senior technology class at school, and we're using 3D printed parts, but sometimes they are a little too large and need some sanding down. After having one classmate spend a week sanding down one piece, my other classmate had enough of this and brought out the dremmel with a sanding bit. Turned it on to full power and started sanding. 3d printed plastic. To say the least, a blob of plastic would be a good representation of what was left. Blackened and melted. Don't use a dremmel to sand 3d printed plastic. Take the slow route.
  • starfleetengineer75
    starfleetengineer75 over 6 years ago
    The worst thing to use is a razor knife, sweaty arms and a damp basement. Was hooking up a 220 volt outlet for my father in law for their dryer. Was stripping the wires at the breaker box and sneezed. Well the worst thing that could ever happen did. The knife slipped and hit a charged wire. And of course it was a 220 wire. It melted the blade and knife, blew me back a few feet. Went upstairs and they said my hair was pointing backwards. After a few minutes I was fine, but found out I fried my watch. This is the point I decided I'm not working on a powered breaker box again!
  • rcwelch7
    rcwelch7 over 6 years ago
    The absolute worst tool I have used for an electronics job is my teeth! Chipping a tooth stripping a wire was almost a guarantee with each wire stripped.... over the years with each project making them worse and worse till the look of my teeth and pain that was caused by the chips was unbearable! I now have dentures and needles to say they are too also chipped! This is for one , the worst tool to use on an electronics project! And two an equally bad habit to break! It is absolutely a better idea to spend the $20 or $30 on a good set of strippers or at least the $5 on a cheap one!!!!!image
  • sherdon.uy
    sherdon.uy over 6 years ago
    I would say the worst tool is a crimping tool meant for RJ-11 jacks when wiring up a prototype circuit. It was a slow and painful process to build this Z8 microcontroller-based system. As a bonus, you get a spaghetti network of wires that is difficult to go through when troubleshooting. You may see this in the image below:
  • ntewinkel
    ntewinkel over 6 years ago in reply to leosmith
    leosmith  wrote:
    Oxyacetylene torch for soldering surface mount components.
    I prefer using an arc-welder.
  • rdaragon
    rdaragon over 6 years ago
    Just about any "improvised" tool can ruin your day.... A knife used as a screwdriver that slips the wrong way... Using a paperclip as a set of forceps to hold... well, anything that's not paper....
    But, one that I've seen bite people on the backside, including myself, is using electrical tape....
    No, that's it. Just using it.
    I had a classmate try to use some to secure some wire while working on a project. It might have been a good idea, except the prof needed to see the wires... And apparently, he needed to troubleshoot the project because something wasn't connected correctly.
  • samyakjain
    samyakjain over 6 years ago
    As starting experience of my school I have juts started soldering practice and purchase the soldering Iron and solder wire from market (you guys won't believe I got this soldering iron in just 2$ and solder wire around 1$ ) afterward as I grow and purchase the new parts, components.
    But it's about month before I forgot my solde iron in college lab and I used my old one but as Hazard soldering accidentally start burning and it's plastic body started melting. And after this much years passed I open that iron and seen that even there no protection circuit at all the Power supply was directly connected to the iron rod.
    As conclusion do not use chip electronics products always go with the standards      I made mistake because at that time I was just 15 years old and don't know about connection, protection circuits.
