Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11271 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • neuromodulator
    neuromodulator over 6 years ago
    I friend of mine doesn't have hand tools and every time we have had to repair something at his house it has been with "wrong tools". With wrong, I mean, spoons, forks, butter knives, scissors, etc. They usually either can't get the job done or the results are really bad. Here I'll show you a video I made of what it is to strip and solder a cable with the wrong tools:
    (apparently I can't embed video)
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to leosmith
    leosmith You're really kidding aren't you?
  • leosmith
    leosmith over 6 years ago
    Oxyacetylene torch for soldering surface mount components.
  • greihawk
    greihawk over 6 years ago
    By far the absolutely worst tool to use in electronics is my Brother, i cannot even count the amount of things he "fixed" for me growing up. He was convinced that he could take anything apart and make it better, gameboys, our SNES, even my mothers work laptop one time. Still to this day he believes that he is a whiz with electronics.
  • darwin3
    darwin3 over 6 years ago
    This past spring out at my mother-in-law's house we were trying to charge a battery on her lawnmower and there was an intermittent short in cables from charger to the battery terminal clamps. After messing with the cables I assumed the short was in the wires near or at the board of the charger. After 10min to get the charger case apart, it is all good. Then looking at the clamps I see the all the wire strands are broke on one clamp and only the insulation is holding the clamp on. Luckily the other side of the clamp is the same and can be crimped onto a frest end of the cable but I dont have a proper tool to crimp this big of wire. So I used vise grips to fold the tabs into the wire strands then tried using my cheap soldering iron to solder the connection for security. My iron cant put out enough heat to make a good joint, so in a last resort option, I grabbed a propane torch (to sweat copper pipe kind) and heated the back side of the clamp. Shockingly it worked.
    • Vote Up +5 Vote Down
  • 31337
    31337 over 6 years ago
    a drill bit in the fingers when you can't find your vero board track cutter.
  • ntewinkel
    ntewinkel over 6 years ago in reply to koudelad
    koudelad  wrote:
    For all who hate wire strippers... This is the last tool you will buy image
    https://www.youtube.com/watch?v=hOvL76Dn8r4
    Those automatic wire strippers are great!
    I first saw one when my mechanic nephew used one to fix some wires on a car. Previously I was only aware of those cheapo sketchy ones mentioned above image
    I then immediately bought a cheapo automatic stripper off eBay, but it wore out very quickly.
    I love this Jokari one I received from element14 as part of a shopping cart once:
    https://canada.newark.com/jokari/t20050/automatic-wire-stripper-super4/dp/33P8621
    Comparing it to the eBay one, you definitely get a whole lot more quality with the Jokari. I use it all the time.
    For heavier wires, like automotive/boat and house wiring, I have a similar tougher one I got at Canadian Tire a few years ago. It's not as nice, but good for the big stuff.
    https://www.canadiantire.ca/en/pdp/mastercraft-automatic-self-adjusting-wire-stripper-0584570p.html#srp
    Cheers,
    -Nico
  • theinternethelpdesk
    theinternethelpdesk over 6 years ago
    I once had someone who tried to "help me" sort their computer out before I got there with glass cleaner and a microfiber cloth on the internals.  I guess they didn't know about static electricity and what it does to silicon chips. Not to mention not unplugging it so the motherboard was still partially powered whilst spraying water on to it.
    I've never felt so bad explaining to someone how everything they did cost them a few hundred bucks.
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to shabaz
    shabaz  wrote:
    My mum would say the worst tool tool for electronics is her dressmaking scissors : ) Or nail clippers : ) I've ruined a fair few dressmaking scissors cutting wires as a kid I expect..
    I have also ruined few scissors and a nail clipper image. But my brother have ruined many nail clippers by cutting wires and I still have some of these from our school days.
  • gustavovelascoh
    gustavovelascoh over 6 years ago
    {gallery:width=600,height=300} WORST tools for an electronic-related task
    General soldering: Lighter
    Fine soldering: an overrated soldering iron (and viceversa)
    PCB storage: boards over boards in a box
    • Reflow Oven: Kitchen oven (not microwave of course)
    • PCB or component holder while soldering: Your hands/fingers
    • Solder paste application over stencil: Debit/Credit card
    Cutting/stripping wire: Teeth, nails, nailclipper, scissors, lighter
    PCB cleaning: water, acetone
    BONUS: WORST use for an electronics-related tool:
