Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11388 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • 14rhb
    14rhb over 6 years ago in reply to Gough Lui
    Those are great and funny stories, thank you for sharing them.
    I'm sure by now you've perfected the "finger test of hot items" as, the brain telling finger to touch surface, brain says to move finger off surface and brain then thinks about if it was hot: for reasonable hot temperatures this does indeed work. What doesn't work is brain tells finger to touch surface, brain thinks about how hot that is and then brain tells finger to move off. And if using the first method nothing registers then a succession of quicker taps ensues to gauge the actual temperature.
    • Vote Up +6 Vote Down
  • Gough Lui
    Gough Lui over 6 years ago
    I'd have to say that the worst tool for an electronics job is probably my index finger.
    When I was younger, just starting out in electronics, I had a passion for building kits. It was supposed to be a gentle way to get yourself acquainted with the art of reading component values, populating boards, soldering, clipping leads, testing, troubleshooting and providing the finishing touches with as little risk and as much convenience as possible.
    The first mistake is a very common one - I was soldering a PCB pin to a board as an attachment point for a wire, as I was instructed to do. Not having a set of helping hands or anything, I shoved the pin into the board, held the pin down with my index finger firmly while gripping the sides of the board with the same hand, and using the other hand grabbed the iron and the solder and began to solder the pin. Needless to say, I immediately grasped the concept of thermal conductivity when I grew a blister right in the middle of my index finger ... making work more painful for about a week.
    I thought I'd learned the lesson, but then, I got caught again when it came to tinning a short piece of wire. As I had a crummy thermally-balanced iron, heating times were a little inconsistent, so I was holding the wire at the insulated end and tinning the stripped end. Needless to say, the insulation eventually gets hot and melts as well ... giving me another burn. Add that to inadvertent soldering-iron contact when I used one without a stand ...
    Many years passed and I became more experienced at soldering. Being burned by the iron became a thing of the past. But just last year, I burned my index finger again. This time, it was a bit of a funny story - I usually hold solder with the left hand, feeding it into the iron on the right. Well, on my bench, I had a scrap of 0.8mm 60/40 solder, and a scrap of 1mm tinned copper wire. Guess which one I grabbed and tried to feed into the iron? I was a bit frustrated as it seemed to be taking forever to melt ... and then the heat got to me! D'oh!
    Sometimes, it's not the iron's fault. I have another habit - namely of testing the temperature of something with my finger. Having built a kit, I got a diode in the wrong direction and it shorted out the supply voltage, crowbaring it down to zero. I was wondering what was taking all that current, so I started touching components to see which ones were hot. Needless to say, I burnt my finger on an 1N4004, which taught me a lesson - perhaps use a less important finger instead ... or get a thermal camera.
    But the finger also has a number of remarkable properties - being conductive and attached to the body, I've gotten zapped by touching things and I've also zapped things (e.g. MOSFET gates) by touching them through ESD. My fingers are dangerous.
    - Gough
    • Vote Up +9 Vote Down
  • Gough Lui
    Gough Lui over 6 years ago in reply to 14rhb
    Yikes - I've heard of people cutting notches into expansion cards and RAM because it wouldn't "fit" but ... totally destroying a video head like that is a new one. I've cleaned plenty with high purity isopropyl alcohol, low-lint swabs, moving along the direction of travel (not up and down, as one can snap the head), sometimes vigorously if the iron oxide/chrome dioxide/cobalt dust is stubbornly stuck in the gap, then leaving to dry. I can't imagine how one could really screw that up so bad! Probably would have left some scratches on the tape too!
    - Gough
  • 14rhb
    I'm in two minds as to confess to this. Years ago as a young technician I watched a colleague use a spanner wrapped in PVC insulation tape to undo the bolts on a live 440v AC connection strip: luckily all ended well. Had the spanner slipped then because the insulation was not very tough it would have easily been punctured. That would have been followed by the inevitable arc/plasma and some horrendous burns. A proper VDE spanner set is the only credible solution as the insulation on those is much stronger e.g. Product LinkProduct Link
    • Vote Up +7 Vote Down
    shabaz over 6 years ago in reply to the-dubster
    Wow! Glad there was no serious damage. I did hear about RF burns on 20W, maybe it was about you! I worked on some of the hardware, some Clansman successor equipment which was 20W too, and also some of the handheld UHF range (Cougar). That was long-deployed after I started on it, but I had some post-production design projects (like finding ways of adding extra channels in software for customers, since the initial production version only allowed selection of a few channels from the rotary control on it). The antenna tuning units were very cool.. always liked hearing the rapid relay buzz while it found the best setting! : )
  • the-dubster
    Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part of the procedure required me to place a shorting link - made of 2 croc clips and a piece of wire - between 2 terminals.
    So, working carefully I held the insulated croc clip and attached it to the live terminal - currently at a potential of 980V DC - and then was surprised to feel a large jolt in my right arm.
    I had forgotten that holding the other (uninsulated) croc clip was a bad idea. One sharp kick resulted in (according to my oppo), me clenching my jaw tight, peeling my lips back in a rictus grin, and jumping up quite a bit . . . .
    All I remember is a big jolt and a numb feeling in my right arm midway between the elbow and shoulder. I was tempted to have a line tattooed there to indicate 980V on the scale . . . .
    Lesson learned (for a bit at least), right up to the point I SWR matched a ground spike antenna on a Clansman Radio with AE Tuning Unit and 20W PA fitted, with my hand resting on another AE attachment point. . . . . . 20W of RF straight through my skin , one small black hole and a cooking smell.
    But that's another story all together . . . . at least I got close to 1:1 SWR.
    • Vote Up +10 Vote Down
  • jman095
    jman095 over 6 years ago in reply to shabaz
    I know how you feel. My mom makes jewelry, so I decided to borrow some of her tools. Let’s just say it didn’t end well..
  • stevesmythe
    stevesmythe over 6 years ago in reply to shabaz
    I thought it was just me that couldn't use that crimping tool properly. It's pretty hopeless as a wire stripper too. Never tried to cut an M3 bolt with it, though!
    dougw over 6 years ago in reply to Gough Lui
    I have a crimper that is very similar to this - which works just fine.
    The jaws have a slight difference, which concentrates more crimp force with less handle force. And the steel looks slightly heavier.
    As 14rhb mentioned I also like the screw cutter.
    Early in my electronics career, in fact before I even had a career, while I was a student in High School I had an electrifying experience.  Our High School was lucky to have a very talented and creative electronics teacher, Mr. Wilson, who was instrumental in setting up a FM stereo radio station at the school.  The station was maintained and run by students. Having completed my first year of electronics class (also run by Mr. Wilson), I was allowed to apply for a position on the electronic staff for the radio station, which proved to be a very positive step in inspiring my future career.  One day I was asked to remove a piece of equipment from within the radio station studio (partially housing some of the broadcast equipment, i.e exciter, RF monitors, etc.).  I immediately when to work, assessing the connections and starting to remove the piece of equipment.  With a trusty screwdriver in hand, I when about removing the connecting wires when there was a loud bang, a bright flash and then absolute darkness and quite.  My heart was pounding (at a very high rate) and I sort of lost track of what was going on.
    In my haste to remove the equipment I had forgot to shutdown power to the device.  The last connection that I was working on removing was the power to the device (I was unscrewing the power cord).  The screwdriver had shorter out the line cord.  I was quickly removed from the area and the teacher and other staff members cleaned up the mess that I had made and worked to get the radio station up and running again.  Later that day, one of the more senior members of the electronics staff had told me that they were able to get everything up and running again, except for the frequency monitor (that constantly measured the frequency of the FM transmitter/exciter) which was damaged by a power surge in the process.  I was told that the frequency monitor costed $15,000.  I was pretty shook up about the damaged that I caused, which further caused mental stress/confusion.  After another hour or so, the teacher came in and took me aside.  He had told me that the frequency monitor was OK, but the exciter module had suffered a surge and the main crystal was damaged, only a $75.00 part. A while later, one of the other staff members took me aside and told me everything was OK, the others were just joking me.
    Later that day, we were having a class with was in preparation for our up and coming FCC test for our radio operators licenses.  On of the group was collecting a list of names of students that needed text books.  I had raised my hand, and he start writing my name on the board .... Gene ... then he stopped and erased that, and wrote F.M. BurnEmUp.  That became my radio station name for the rest of high school.  I even received mail with that name for several years after school.  To this day, on a facebook group for the radio station, I am still referred to as F.M. (for short).
    Right tool, but used in the wrong way.  I learned a lot from that experience.
