Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11381 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
    shabaz over 6 years ago in reply to phoenixcomm
    Hehe probably the blast shape on the scissors is not easy to conceal from your parents afterwards : )
    shabaz over 6 years ago in reply to the-dubster
    Wow, that's brave. I think our first TV always gave a mild tingle when changing channels on it, so I tried to stay clear of the insides of those : )
    But on home-made circuits I sometimes used to use a lip test on TO-18 cans to see if they were gently warming up : ) But sometimes the heat rise was quite rapid with those : )
  • wombaticus
    wombaticus over 6 years ago
    The worst tool for any job is the one that is almost the right tool and 'will do'.
    You will always spend more time fiddling, trying to make it fit, shaving bits off, adding bits, removing lumps of flesh, electrocuting yourself or poking yourself in areas you really didn't know had that many nerve endings.
    Invariably the right tool for the job will be found seconds after breaking the thing you were trying to mend, build or install in the first place.
    Cenydd
    • Vote Up +6 Vote Down
  • the-dubster
    the-dubster over 6 years ago in reply to 14rhb
    I've certainly tested something for heat in the past - wet my finger too to get the 'sizzle' before it really burned . . . . . . unfortunately it was the case of a TO3 transistor (the carbon resistor downstream was doing a passable impression of an arc lamp).
    I didn't notice the label on the TV chassis  "Warning, Chassis Live Regardless Of Mains Polarity"    -    it was hot alright, hot to the tune of 240V ac mains!
    Maybe I should steer clear of electrics/electronics . . . .  image
    • Vote Up +8 Vote Down
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to neilk
    shabaz I think I broke the one hand rule in maybe the 7th grade (we went to High School for a basic electronics class). And I wanted to use the Oscilloscope for the first time, remember the Hickock round tube. Well, I got the scope out of the cabinet and put it on a table, and plugged it in.   While touching the case I rotated the intensity/power control and got knocked off my feet.
    After I regained my self, the question was why, so I took the case off (permission first), and saw the metal shaft coming from the back of the scope to the front. The next day I repaired it for good. Removed pot shaft, etc. I cut the shaft and installed a flexible coupling (ceramic). fins.image
  • 14rhb
    14rhb over 6 years ago in reply to phoenixcomm
    ouch and OUCH.
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to shabaz
    shabaz oddly you mentioned me twice:
    once a long time ago (when I was just a wee thing) we were moving from NYC to Long Branch, NJ, and my Mom and Dad where cutting string or rope. So I (as the story goes) Got Moms good pair of snips, and crawled up under the desk. And cut the wire to the vac. Bright flash, I cried, and a pair of burned snips.
    And yes I have stripped wire more than a few times with your God-given wire strippers (teeth)  image
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to dougw
    dougw  As a female of the group, you must do three things:
    1. remove your rings!
    2. remove any dangles ie long neckless, scarfs, and or earnings.
    3. Put up your long hair.
    The list is in the order of pain!
    1. Ring: Could lose a finger or worse! when playing with power!
    2. Hair: Can fall in to or get caught by machinery.
    3. Neckless: Can fall in to or get caught by machinery.
  • neilk
    neilk over 6 years ago
    Back in the mid 60's (my late teens!!) I fancied myself as a bit of DJ and used to do the music at parties - modified portable gramaphone, reel-to-reel tape recorder, home-made 10Watt valve ampilifer (Mullard design book) and a pair of home made loud speaker cabinets. My father would deliver me and the kit to wherever the party was and collect me afterwards, in his car.
    I arrived at one party to find there was only 1 power socket and I needed a minimum of two - no adapter, no plug board, no tools!! I managed to find a screwdriver and wired 2 bits of kit into one plug....not a serious task for me in those days!!
    Successful evening but went on a bit and Dad was waiting outside in the car.......I panicked because he didn't like being kept waiting. Impossible to carry the two pieces of kit that were wired into the same plug, no time to unwire the plug.... so cut the power cords....with a pair of hefty scissors.....while still plugged in......and switched on!!!!!!!!!!!!!!!!
    I got a nasty jolt and the fuse in the plug blew, saving the fuse in the house distribution box.....I was lucky!!!!! Of course they were fuse wire in those days.
    After that I made up a plugboard and always carried a small toolkit, including insulated cutters!
    Neil
    • Vote Up +7 Vote Down
  • Gough Lui
    Gough Lui over 6 years ago in reply to 14rhb
    14rhb - I find it best when you outsource the finger jobs to someone else image. Hey, umm ... does this feel hot to you?
    - Gough
