Documents Holiday Gift List Giveaway - Test & Measurement Tools on the Go!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 7:59 PM Date Created
  • Last Updated Last Updated: 25 Feb 2020 11:13 AM
  • Views 5305 views
  • Likes 17 likes
  • Comments 69 comments
Test & Measurement Tool Giveaway for Folks On The Go
element14 Presents  |  Engineer and Maker Wish List  |  Workbench Wednesdays
Unsupported video URL format.
It's that time of the year again - when you'll be traveling over the river and through the woods and so on . . . But you don't have to leave your test and measurement tools behind if you have these great products selected for this giveaway!
To win this wonderful set of holiday gifts for you or that special engineer on your list, just tell us about your experience (real or imagined) where you were away from your workbench but you really needed your test tools. Drawings, pictures and postcards will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product NameManufacturerQuantityBuy KitBuy Kit
MULTICOMP PROPC USB Oscilloscope, 2 Analogue, 1 Ext Trigger, 25 MHz, 100 MSPS, 5 kpts, 14 nsMulticomp1Buy NowBuy Now
MULTICOMP PROHANDHELD DMM WITH BLUETOOTHMulticomp1Buy NowBuy Now
DURATOOLDigital Caliper, Carbon Fiber, 150mm/6", 0.1mm ResolutionCuratool1Buy NowBuy Now
Winners - We Need Your Details!
Congratulations to paj , kmikemoo  and wombaticus , once cstanton has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can image
imageTest tools on the go Giveaway.pdf
  • holiday2019
  • test and measurement
  • colporteur
    colporteur over 7 years ago +7
    In the summer of 2019 I was visiting my 83 year old Aunt in her 100 year old home. Home improvement shows had convinced her that white light switches and plugs were more ecstatically pleasing. A change…
  • 14rhb
    14rhb over 7 years ago in reply to colporteur +7
    I had foolishly removed the two, three way light switches at either end of the hallway without documenting the connections. You are not alone on that one - now if the wiring behind a fitting or socket…
  • rsc
    rsc over 7 years ago +6
    There have been many many times when I've been visiting a friend or relative and they say "While you're here, can you take a look at this - it's not working". Of course I have no tools with me, and all…
  • ntewinkel
    ntewinkel over 7 years ago
    I tend to run into interesting scenarios when visiting my father in law, when it comes to electrical things and often more specifically with electrical things in boats.
    One time they asked me over to help replace the electric hot water tank. He had turned off the breakers. Wait, I should be using airquotes: "turned off the breakers"... but "for some reason" it gave off a massive spark when he touched the wires to something!  yikes... so yes he turned off some random other breaker. If I recall correctly, there was a '1' missing, so instead of 14/15 it said something like 4/15. In any case, I have a no-contact line voltage tester and we quickly found the correct breakers to turn off and replace the tank so he could get into hot water in a much better way image
    The boat... sigh, yes the boat... there's always something rusting when dealing with salt water near electronics. My wife and her dad go fishing a lot, so they own a little boat together. And I guess the maintenance of the electrics have become my job haha image
    And my father in law has tools that must have been inherited up through the generations from the early 1800s... "I have a wire with a light for testing!"... thankfully I do generally remember to bring my trusty digital multimeter for these sorts of things. "Go short out something else somewhere else!" In one case he did actually end up shorting out power to ground and ended up with a 12 foot long hot wire through the boat, melting some seat vinyl along the way - yikes! Let's buy a fire extinguisher for the boat, ok?
    One little tool thing he uses is a little 12v light he uses to probe with. I find it's not very reliable though, as in one case he concluded there was no power on certain circuits and he was about to tear out and replace all sorts of expensive parts of the boat, but then when I tested with the DMM I noticed it was fine on the battery side, but somehow reduced down to about 7 volts on the other side of the fuses - turned out the corrosion in the fuse box was causing too much resistance. Cleaning all of fuse holders and the fuses carefully with some fine sandpaper restored full power to the bilge pumps, marine lights, wipers... all those little details that might come in handy while out on the water image  (bilge pumps plural... there's a nearly-sinking story that goes along with that, of course)
    The funny thing is he usually tries to push his old tools into my hands when I go to check things, because he "doesn't trust" those fancy multimeters I use image
    (So yes, I often secretly check things when he's not there haha!)
    Cheers,
    -Nico
    • Vote Up +5 Vote Down
  • ntewinkel
    Cheers,
    -Nico
