Documents Holiday Gift List Giveaway - Test & Measurement Tools on the Go!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 7:59 PM Date Created
  • Last Updated Last Updated: 25 Feb 2020 11:13 AM
  • Views 5231 views
  • Likes 17 likes
  • Comments 69 comments
Test & Measurement Tool Giveaway for Folks On The Go
element14 Presents  |  Engineer and Maker Wish List  |  Workbench Wednesdays
Unsupported video URL format.
It's that time of the year again - when you'll be traveling over the river and through the woods and so on . . . But you don't have to leave your test and measurement tools behind if you have these great products selected for this giveaway!
To win this wonderful set of holiday gifts for you or that special engineer on your list, just tell us about your experience (real or imagined) where you were away from your workbench but you really needed your test tools. Drawings, pictures and postcards will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product NameManufacturerQuantityBuy KitBuy Kit
MULTICOMP PROPC USB Oscilloscope, 2 Analogue, 1 Ext Trigger, 25 MHz, 100 MSPS, 5 kpts, 14 nsMulticomp1Buy NowBuy Now
MULTICOMP PROHANDHELD DMM WITH BLUETOOTHMulticomp1Buy NowBuy Now
DURATOOLDigital Caliper, Carbon Fiber, 150mm/6", 0.1mm ResolutionCuratool1Buy NowBuy Now
Winners - We Need Your Details!
Congratulations to paj , kmikemoo  and wombaticus , once cstanton has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can image
imageTest tools on the go Giveaway.pdf
  • holiday2019
  • test and measurement
  • colporteur
    colporteur over 7 years ago +7
    In the summer of 2019 I was visiting my 83 year old Aunt in her 100 year old home. Home improvement shows had convinced her that white light switches and plugs were more ecstatically pleasing. A change…
  • 14rhb
    14rhb over 7 years ago in reply to colporteur +7
    I had foolishly removed the two, three way light switches at either end of the hallway without documenting the connections. You are not alone on that one - now if the wiring behind a fitting or socket…
  • rsc
    rsc over 7 years ago +6
    There have been many many times when I've been visiting a friend or relative and they say "While you're here, can you take a look at this - it's not working". Of course I have no tools with me, and all…
  • mahmood.hassan
    mahmood.hassan over 6 years ago
    Recently I went to my village to have enough open space to safely test my recently built quad copter and functionality of its autopilot. Unfortunately I failed miserably and return to my home unsuccessfully.
    My initial plan was, First I will test everything using q-ground control app on my android phone by connecting the MAVlink telemetry module with it though micro-usb to micro-usb cable. And as a backup plan I will use the laptop as ground control station/debugging etc.
    Before leaving for this trip I put at least one extra items of each type except micro-usb to micro-usb for my mavlink telemtry module and when I tried to connect the mavlink telemetry module with my phone then I found out that this brand new cable was not working and at that time I really wished for my multi meter to test the continuity of this cable and also a wire cutter/stripper so I could join two normal micro-usb data cables together. So I flew my drone manually and soon battery ran out so my first day of testing was ended without doing anything useful.
    Lesson One: Always less expected things will ruin your day like mine was ruined by this small cable.
    Next day when I used my laptop as ground control station, I found out that GPS signals are not giving sufficiently stable horizontal position due to bad weather. I tried everything even changed the firmware to default PX4 stable releases v1.9.2 and v1.10.0 in the hope of getting better EKF2 result but everything was fruitless and still getting the same error. This time this bad weather and GPS issue was getting on my nerves and now 2nd day was ruined without even able to ARM the autopilot so again I was not able to fly or test anything. I also checked the GPS output of my cell phone to make sure its the bad weather thats effecting th GPS output and I found out that my position was continuously changing in Google MAP. That was slight sign of relief that drone hardware is fine.
    When I was getting troubled by the bad pix-hawk 4 GPS module output at that time I was really wishing for some tool that can generate GPS signals alternate so so I could replace the onboard GPS with it in that really bad weather.
    Lesson Two: Never underestimate the power of Nature and always be ready for the worse.
  • mahmood.hassan
