Arduino Tutorials
  • Arduino Tutorials
Arduino Tutorials
Forum I am new Arduino.. from where should I start... ???
Join Arduino Tutorials to participate - click to join for free!
  • Subscribers 26 subscribers
  • Views 1882 views
tanvithakur
tanvithakur over 6 years ago
I do have Arduino Uno..
Where can I find entire steps to perform?
  • aswinvenu
    aswinvenu over 6 years ago +2 suggested
    Hi Tanvi, welcome to the world of micro-controllers! I think the following steps will help you. The architecture of Arduino UNO (Read about ATmega328P also) The architecture of Arduino programming ( understand…
  • ankur608
    ankur608 over 6 years ago +1
    Arduino 'Examples' within the Arduino IDE, is the first Step. Working with sensors, is yet another simpler task that can be accomplished by following the connection diagrams(Fritzing) along with their…
  • parachaser
    parachaser over 6 years ago +1
    Start with the Arduino Uno R3 Download the Arduino IDE.. The programs that run the Arduino are called sketches these sketches can be found in the Arduino IDE software that you downloaded.. Look for samples…
  • ankur608
    0 ankur608 over 6 years ago
    Working with sensors, is yet another simpler task that can be accomplished by following the connection diagrams(Fritzing) along with their codes, easily available allover the Internet and Community.
  • clem57
    0 clem57 over 6 years ago in reply to ankur608
    Try. https://arduino-tutorials.net/ tanvithakur any place is fine so long as you have fun
  • parachaser
    0 parachaser over 6 years ago
    Download the Arduino IDE.. The programs that run the Arduino are called sketches these sketches can be found in the Arduino IDE software that you downloaded.. Look for samples. You will see basic code such as "blink"  blink is a code for blinking a basic LED at different speeds etc.. when you click on this sample code a window will pop up showing you the code that will be loaded to the Arduino board / module. Read the text ! there are literally dozens of videos on youtube that show you how you can edit the code to do all kinds of things like making the LED blink faster etc. Watch lots of videos based on Arduino.. you will be really surprised at the things you can accomplish.. You will hear about Processing just stick with the basics for a few months. Processing is the next step.. You should have some understanding of Circuits, if not You should learn about building circuits before getting into Arduino.
  • aswinvenu
    0 aswinvenu over 6 years ago
    Hi Tanvi,
    • The architecture of Arduino UNO (Read about ATmega328P also)
    • The architecture of Arduino programming ( understand the stepup and loop functions)
    • Read upon GPIO functions and Pins ( General purpose Input Ouput)
    • Now you compile and run the blink sample code
    • Now take one more step into peripherals - UART (serial communication); What happens when you use Serial.print() function
    • Learn how to change the blink intensity by varying voltage (PWM - Pulse width modulation)
    • How to communicate with external sensors ? Using SPI, I2C or UART
    • How to control external transducers
    The best way to learn is by doing some project. Take a real world problem and try to make an Arduino based solution for it. This may require multiple sensors and transducers. That will make you learn about different communication protocols. Then you will learn how to use them with the Arduino.
    Happy learning!
    Aswin
  • parachaser
    0 parachaser over 6 years ago in reply to aswinvenu
    Very nice , Very specific, Thank you
