Arduino Tutorials
  • Arduino Tutorials
Arduino Tutorials
Forum arduino for beginners
Join Arduino Tutorials to participate - click to join for free!
  • Replies 12 replies
  • Subscribers 32 subscribers
  • Views 3381 views
lj26
lj26 over 8 years ago
Any tips on how to program an ARDUINO for beginners?
  • luislabmo
    luislabmo over 8 years ago +6
    Well in his defence, he was looking for tips... I guess the tutorials may help you learn some in the long term This is my best tip for Beginners with Arduino. Try to start with the the Built-In examples…
    shabaz over 8 years ago +5
  • Gough Lui
    Gough Lui over 8 years ago +4
    Guys how you doing, I just want to start learning about how I can work with Arduino , where I can find a basic program to get started ?
    • Vote Up +5 Vote Down
  • Gough Lui
  • luislabmo
    Well in his defence, he was looking for tips... I guess the tutorials may help you learn some in the long term image
    This is my best tip for Beginners with Arduino. Try to start with the the Built-In examples they were written with beginners in mind..... if you are just starting with components... well many companies sell starter kitsstarter kits that bring the necessary components to try most many of the examples.
    Luis
    • Vote Up +6 Vote Down
  • naiju1994
    naiju1994 over 8 years ago
    i would recommend you to follow lessons by Paul McWhorter from toptechboy.com
    here is a playlist of the aurdino lessons by paul McWhorter
    https://www.youtube.com/watch?v=d8_xXNcGYgo&list=PLGs0VKk2DiYx6CMdOQR_hmJ2NbB4mZQn-
    i hope you find it useful!
  • 14rhb
    14rhb over 8 years ago
    For anyone starting out, the Arduino is really easy to use but often the stumbling point is getting the initial setup going. This is the simple steps for anyone getting stuck early on...
    • (1) Download and install the ArduinoIDEhttps://www.arduino.cc/en/Main/Software - following details for drivers/and your Operating System
    • (2) Plug the Arduino into your USB port
    • (3) Find which port it is attached to using Windows Device Manager or type ls /dev/tty* under Linux
    • (4) Run the ArduinoIDE
    • (5) In the IDE, select the board you have plugged in using TOOLS/BOARD
    • (6) In the IDE select the port you identified in step (3)
    • (7) As luislabmo mentions, the built in examples are great. Choose the most basic to start with from FILE/EXAMPLES/ 01.BASICS/BLINK
    • (8) Click SKETCH/UPLOAD....this will take a few minutes and should start the LED flashing on your Arduino.
    If that all works, congratulations as you have a working setup. Start to modify the C code to learn more (changing the time delay to make the LED blink faster or slower is always a good check ) or load in some of the other examples.
    Sometimes the above may fail and would need a follow up post in Element14, Arduino forums, internet searches etc to track down the problem.
    Rod
  • luislabmo
    luislabmo over 8 years ago in reply to 14rhb
    (9) If can't seem to find what you are looking for, shabaz can point you with the right search on google. image
    Luis
  • 14rhb
    14rhb over 8 years ago in reply to luislabmo
    I found the Arduino Starter Kit was a great introduction Element14's Arduino Starter Kit Competition - Part 1 ; there were a few failings in the kit (mainly some cheap components) but overall it was very informative and great fun.
    Rod
  • anuag_ashim
    anuag_ashim over 8 years ago
    I am also new to Arduino.
    The way like everyone suggested is to download it and get started. Plenty of examples are there online
  • txtxdru
    txtxdru over 8 years ago
    The book "Exploring Arduino: Tools and Techniques for Engineering Wizardry" really helped me when I first started learning to use the Arduino.
  • abrain
    abrain over 8 years ago in reply to txtxdru
    I like Simon Monk’s pair of Arduino books.
    image image
    https://www.amazon.co.uk/Programming-Arduino-Getting-Started-Sketches/dp/1259641635/ref=sr_1_1?ie=UTF8&qid=1541028370&sr=8-1&keywords=arduino+simon+monk
    https://www.amazon.co.uk/Programming-Arduino-Next-Steps-Sketches/dp/0071830251/ref=sr_1_2?ie=UTF8&qid=1541028639&sr=8-2&keywords=Programming-Arduino-Next-Steps-Sketches
    A
