Arduino
Arduino
Blog Access GPIO of Arduino from Raspberry Pi using Firmata & JAVA
  • Author Author: oksbwn
  • Date Created: 13 Sep 2017 4:02 PM Date Created
  • Views 1133 views
  • tutorial
  • raspberry pi
  • getting started
  • java
oksbwn
oksbwn
13 Sep 2017
Firmata is a protocol that is used to communicate with microcontrollers from any tablet/pc over the serial interface. There are implementations of Firmata for many other platforms too along with Arduino. You can find support for Firmata if you are using any Arduino IDE released after 2008.Use of Firmata lets you access GPIO of Arduino from any host device natively without uploading the sketch each time you change the sketch. You can use Arduino as ADC for your Pi as it doesn't have native ADC pins, you can also interface a whole lot of sensors by the additional GPIO that you will get after connecting the Arduino which eliminates uses of the port expander and ADC ICs to be interfaced with Pi.In this video, I have shown a basic example of blinking the onboard LED of Arduino from Raspberry Pi by using JAVA and for this, we are going to use the firmata4j library.
Links:
Firmata4J Library:  http://bit.ly/2xixy4K
Jar File of Library:http://bit.ly/2wTZ74C
(Dependency for Firmata4J) JSSC (Java Simple Serial Connector): http://bit.ly/2jm7wYU
(Dependency for Firmata4J) SLF4J API Module: http://bit.ly/2y38ehc
Firmata Protocol Page: http://bit.ly/2wVyTyI
Protocol Details: http://bit.ly/2xiC6YP
Related Videos:
Java Application on Pi Playlist: http://bit.ly/2eB1O2K
IOT With Raspberry Pi: http://bit.ly/2rPEHq8
