Arduino
Arduino
Blog Arduino Due Unboxing and Quick Specs
  • Author Author: DaveYoung
  • Date Created: 16 Jan 2013 3:48 AM Date Created
  • Views 1240 views
  • review
  • due
  • dyoung
  • unboxing
DaveYoung
DaveYoung
16 Jan 2013
Key Specs:
There has been a lot of anticipation for the arrival of the Due, and with good reason.  The board's capabilities far exceed other Arduino boards and does a good job rounding out the product line.  Here are some key specs that Arduino proudly publishes on the product's page:
  • $49 price point
  • 32-bit processor at up to 84MHz
  • 54 Digital I/O pins, 12 ADC pins, and 2 ADC pins
  • 2 USB-micro ports: one for programming the Due, the other for interfacing with peripherals
What makes the new board so great?
The Arduino Due, like all Arduino boards, are designed to give users access to the power of Atmel microcontrollers in the easiest fashion possible.  In the Due's case, it leverages the additional power and capabilities of the Atmel SAM3X8E chip to produce its impressive specs.
Most people are interested in how the Due compares with the ubiquitous Uno, running on the well-known Atmega328 chip. Because both boards primarily enable users access to the chips' features, the main differences between the Due and Uno are defined by their respective chip datasheets.  To get right to it, here is why someone would spring for a Due above an Uno:
ParameterUnoMegaDue
Digital I/O:145454
I/O that can PWM:61512
Operating Voltage5V5V3.3V
Analog Inputs (ADC):6x 10-bit16x 10-bit12x 12-bit
Analog Outputs (DAC)<none><none>2x 12-bit 1MSPS
Processor:Atmega 328ATmega2560 SAM3X8E
Processor Architecture:8-bit RISC at16MHz8-bit RISC at 16MHz32-bit ARM at 84MHz
Flash Memory (for firmware)32kB256kB512kB
RAM:2kB8kB96kB
DMA:<none><none>Yes, for up to 17 peripherals
USB Host<none><none>USB OTG
Timers2x 8-bit, 1x 16-bit2x 8-bit, 4x 16-bit9x 32-bit
Power in lowest state (uC chip only)0.1uA0.1uA2.5uA
Ethernet MAC (EMAC)<none><none>1 at 10/100
Price$24.52$47.22$49.99
Clearly, an experienced user gets some serious bang for the buck with the Due.  Although I don't see this causing many problems for Uno or Mega sales.  As capability is added complexity follows; beginners won't have much use for a USB host when starting from square one.  But once they are ready to move on, a $50 upgrade will be waiting at the next level with a Due.
  • Stuartsjones
    Stuartsjones over 13 years ago
    Thanks for posting Dave. We have shared your blog post on our Google+ page!
    https://plus.google.com/u/0/115208019060650803506/posts/PzjUarhxVWu
