Arduino
Arduino
Blog Arduino to C/C++ for LED Cube
  • Author Author: dzuz
  • Date Created: 17 Apr 2019 3:17 PM Date Created
  • Views 2422 views
  • Comments 8 comments
  • led_cube
  • led cube
  • c++ coding
  • 4x4_led_cube
dzuz
dzuz
17 Apr 2019
Does anyone know how to convert arduino code to c/c++?
I have made a 4x4x4 LED cube, but I need to have the code in c/c++, not just arduino code.
If anyone knows of a converter or can link a site to easily learn c/c++ on an arduino, that would be greatly appreciated. Thanks!
-Dan
  • ralphjy
    ralphjy over 7 years ago +2
    You don't indicate why you can't use the Arduino language and IDE. Maybe this is a class assignment? Anyway, you'll need to set up an avr-gcc toolchain and will need to replicate all the stuff that the…
  • jomoenginer
    jomoenginer over 7 years ago in reply to jomoenginer +2
    One other thing, a good book you might want to consider is AVR Programming by Elliot Williams. https://www.amazon.com/AVR-Programming-Learning-Software-Technology/dp/1449355781
  • jomoenginer
    jomoenginer over 7 years ago +1
    Are you using the Arduino IDE? If so, Arduino is C and/or C++. Just when you use the Arduino IDE, you need a setup and loop function instead of a main. You could just add your code as interfaces with classes…
  • dzuz
    dzuz over 7 years ago
    I try to compile the code and I keep getting this error. Does anyone know how I could resolve this issue?
    Thanks!
  • dzuz
    dzuz over 7 years ago in reply to jomoenginer
    I was instructed to change the code below into C or C++. I have to do it with out using digitalwrite. I tried something, to turn all LEDs (turnEverythingOn();) on with the code all the way at the bottom (bolded). Is anyone able to confirm that my code would work?
    //initializing and declaring led rows
      int column[18]={13,12,11,10,9,8,7,6,5,4,3,2,1,0,A5,A4};
    //initializing and declaring led layers
      int layer[4]={A3,A2,A1,A0};
      int time = 250;
    void setup()
      //setting rows to ouput
      for(int i = 0; i<16; i++)
        pinMode(column[i], OUTPUT);
      //setting layers to output
      for(int i = 0; i<4; i++)
        pinMode(layer[i], OUTPUT);
      //seeding random for random pattern
      randomSeed(analogRead(10));
    //xxxxxxxxxxxxxxxxxxxxFUNCTION LOOPxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    void loop()
      turnEverythingOff();//turn all off
      flickerOn();
      turnEverythingOn();//turn all on
    void turnEverythingOff()
         digitalWrite(column[i], 1);
         digitalWrite(layer[i], 0);
    ////////////////////////////////////////////////////////////turn all on
    void turnEverythingOn()
        digitalWrite(column[i], 0);
      //turning on layers
        digitalWrite(layer[i], 1);
    ///////////////////////////////////////////////////////turn columns off
    void turnColumnsOff()
    /////////////////////////////////////////////////////////////flicker on
    void flickerOn()
      int i = 150;
      while(i != 0)
        turnEverythingOn();
        delay(i);
        delay(i);
        i-= 5;
    void loop()
    turnEverythingOn();
    DDRD = 0xFF; //setting outputs
    DDRC = 0x3F;
    DDRB = 0xC3;
    PORTD = 0xFF; //PD0-PD7 8pins
    PORTB.0 = 0xFF; //PB0 & PB1 2pins
    PORTB.1 = 0xFF;
    PORTC.0 = 0xFF; //PC0-PC5 6pins
    PORTC.1 = 0xFF;
    PORTC.2 = 0xFF;
    PORTC.3 = 0xFF;
    PORTC.4 = 0xFF;
    PORTC.5 = 0xFF;
  • jomoenginer
    If so, Arduino is C and/or C++.  Just when you use the Arduino IDE, you need a setup and loop function instead of a main. You could just add your code as interfaces with classes or declarations in a '.h' and either create your own folder under Arduino/libraries or create a 'src' subfolder under your working folder where you place your code in.
    You would then add you code as such
    #include "src/YourCode.h"
    Otherwise, depending on the microprocessor used on the board, you could use Atmel Studio.
    https://www.microchip.com/mplab/avr-support/atmel-studio-7
