Arduino
Arduino
Blog Arduino to C/C++ for LED Cube
  • Author Author: dzuz
  • Date Created: 17 Apr 2019 3:17 PM Date Created
  • Views 2468 views
  • Comments 8 comments
  • led_cube
  • led cube
  • c++ coding
  • 4x4_led_cube
dzuz
dzuz
17 Apr 2019
Does anyone know how to convert arduino code to c/c++?
I have made a 4x4x4 LED cube, but I need to have the code in c/c++, not just arduino code.
If anyone knows of a converter or can link a site to easily learn c/c++ on an arduino, that would be greatly appreciated. Thanks!
-Dan
  • ralphjy
    ralphjy over 7 years ago +2
    You don't indicate why you can't use the Arduino language and IDE. Maybe this is a class assignment? Anyway, you'll need to set up an avr-gcc toolchain and will need to replicate all the stuff that the…
  • jomoenginer
    jomoenginer over 7 years ago in reply to jomoenginer +2
    One other thing, a good book you might want to consider is AVR Programming by Elliot Williams. https://www.amazon.com/AVR-Programming-Learning-Software-Technology/dp/1449355781
  • jomoenginer
    jomoenginer over 7 years ago +1
    Are you using the Arduino IDE? If so, Arduino is C and/or C++. Just when you use the Arduino IDE, you need a setup and loop function instead of a main. You could just add your code as interfaces with classes…
    beacon_dave over 7 years ago in reply to jomoenginer
    Elliot Williams also did a webcast with publisher O'Reilly which may be of interest. It's available to watch on YouTube:
    Programming AVR Microcontrollers in C - O'Reilly Webcast
    https://www.youtube.com/watch?v=ERY7d7W-6nA
    Warwick Smith's 'C Programming with Arduino' is another good introduction for those wanting to move away from the Arduino IDE but whilst retaining the familiarity of the Uno/MEGA hardware.
    https://www.elektor.com/c-programming-with-arduino
    This low cost ATMEGA328P dev board is also very handy to use with the above book as it gives an Arduino Uno footprint without the need for a separate ICSP programmer/debugger.
    ATMEGA328P-XMINI ATMEGA328P-XMINI
  • jomoenginer
  • jomoenginer
    jomoenginer over 7 years ago in reply to dzuz
    Try adding "avr" before iom328.h.
    Such as :
       #include <avr/iom328p.h>
    Or just
    "iom328p.h"
    However, you might want to look at an example such as:
    https://github.com/ElektorLabs/Arduino/blob/master/source2/avr/cores/arduino/avr/iom328p.h
    But, as Ralph mentioned, you need to ensure you have your tool chain set correctly.
    Also, when posting code, it is best to use the ">>" option at the top of the edit window and select the code format you wish to post your code in.
  • ralphjy
    You don't indicate why you can't use the Arduino language and IDE.  Maybe this is a class assignment?  Anyway, you'll need to set up an avr-gcc toolchain and will need to replicate all the stuff that the Arduino code is doing for you.  Here is a link that may help you: https://www.instructables.com/id/AVR-Programming-with-Arduino-AVRdude-and-AVR-gcc/
