Arduino
Arduino
Blog Arduino Uno couple questions before I buy Im new
  • Date Created: 10 Feb 2014 8:05 AM Date Created
  • Views 572 views
e14 Contributor
e14 Contributor
10 Feb 2014
1) I understand that the board has 14 outputs on it.  I would like to use these to control a board with 14 or 16 relays
Not sure where to look for this any ideas
2). I know you can download a software program to control the Uno. Can I use something like hyper Terminal to send the same commands
Thanks
Rick
    dougw over 12 years ago
    Hi Rick,
    There are several relay modules available that claim to work with Arduinos, such as
    16 Channel 5V/12V Mini-Relay Module [BK_RL16_01] - $30.90 : ElecFreaks Store
    To control them from Hyper Terminal would require a small program to be written for your Uno.
    There are also relay modules that can connect directly to USB and be controlled directly from Hyper Terminal, such as:
    http://numato.com/16-channel-usb-relay-module
    http://www.vctec.co.kr/web/product/numato/productdoc/usbrelay16/usbrelay16.pdf
    Doug
  • gadget.iom
    gadget.iom over 12 years ago
    If you are getting started with Arduino then I would suggest you take a look at the Arduino Playground.
    There is a relay specific article there: playground.arduino.cc/uploads/Learning/relays.pdf
