Arduino
Arduino
Blog Arduino Uno Q reflash Debian
  • Author Author: embeddedguy
  • Date Created: 14 Nov 2026 12:23 PM Date Created
  • Views 60 views
  • arduino uno q
embeddedguy
embeddedguy
14 Nov 2026
Some time ago I got the Uno Q from element14 as a gift. I started working on it and then I decided to reflash the Debian to learn the process.
This blog is an explanation of my experience in reflashing the Debian on Uno-Q.
Normally when we power up the Uno-Q we get an Arduino Logo printed on LED Matrix.
Without further explanation first thing to start with after receiving the device is power up the board with USB cable and notice the LED sequence. The board will start booting and the LEDs will print the Arduino Logo. After some time, the LED for the QRB processor will be ON. That means your board is ready and you can login/create user on Debian OS running on the Uno Q.
You can now use the Arduino Applab to create user and log in. After the user is created you can also ssh into the device to get terminal. In the login process you will be asked to provide a username and password. You should also give a meaningful name to your device. This name you can use during ssh process.
For example, if you give your board a name dolorita, you can use
$ arduino@dolorita.local
to login to your board.
How to flash the Debian OS to the board?
Sometimes you may want to reflash the Debian OS the Uno Q. This could be for variety of reasons. Only thing is that it will delete all the data and files that you already have on your device. For flashing the Debian OS there are two ways. With Applab or using the Arduino Flasher CLI.
The first thing is to short the JCTL pin header for entering into bootloader mode. The LEDs on the device will differentiate this by printing USB symbol.
Arduino Flasher CLI
Arduino Flasher CLI is used for flashing new Arduino image to the processor. You can download the Flasher CLI from Arduino website and use the command line to flash the image to the board. There is option to list all the available images that you can use. Also, there is option to first download the image and then flash it.
You can also specify the version using --version <version> command to flash specific image version to the board.
 ./arduino-flasher-cli.exe list unoq
./arduino-flasher-cli.exe flash unoq
./arduino-flasher-cli.exe download unoq
./arduino-flasher-cli.exe flash unoq ./myimag.tar.zst
After the flashing is complete you will get that information from the command prompt. Now you can start the applab and create user. Then you can update the packages on the device. Once the device is ready you can then use it.
  • embeddedguy
    embeddedguy 7 days ago in reply to cstanton
    Yes, because I am more familiar with it. Easy to use. But I would like to use other distributions as well in the future.
    I think the Ventuno has Canonical support and can run Ubuntu. That is really great.
    This post was flagged spam because there is @ in username. But I posted another blog that covers my experience flashing using both the Applab and the Arduino flasher CLI. Slight smile
    Right now, I am trying some camera ML model development. Let's see how it works.
  • cstanton
    cstanton 7 days ago
    Do you prefer debian on the uno q?
