Arduino
Arduino
Blog BYOB Party #3, Infineon Library Available
  • Author Author: Robert Peter Oakes
  • Date Created: 15 Dec 2014 5:50 AM Date Created
  • Views 2459 views
  • Likes 8 likes
  • Comments 8 comments
  • iot_holidaylights
  • byob_party
Robert Peter Oakes
Robert Peter Oakes
15 Dec 2014
Back to the beginning BYOB Party #1, "Bring you own Bulbs" - The Internet of Holiday Lights
OK, so one thing I could not find in all the searching was a Library for the infineon Board so I made one from the sample code, it is not 100% complete yet (More features to add) but its all working so I thought I would share it with you all so you can use it if you so desire
I have moved all the functions into a library called "Infineon"
Added a function to directly set colours "SETCOLOUR(RED)" for example, so far it only has a few colours defined but If i can get a list of RGB values for LED colours 12 bit per colour then I will be happy to add them to this
Colours are White, Silver, Gray, Black, Red, Maroon, Yellow, Olive, Lime, Green, Aqua, Teal, Blue, Navy, Fuchsia, Purple but of course some dont look right on LEDS so i need to refine it over time, if you have some good colour definitions please contribute
This is the modified main loop so you can see how much cleaner it is, it of course can be improved further but this is just a test
  // the loop routine runs over and over again forever:
  void loop() {
    // change lamp colour to red
    RGBLEDS.I2CWRITE6BYTES(ADDRESS, INTENSITY_RGB, 0x0, 0x0, 0x0); // all off
    delay(500); // wait 1000ms
    // change lamp colour to green
    RGBLEDS.I2CWRITE6BYTES(ADDRESS, INTENSITY_RGB, 0x03ff, 0x03FF, 0x03FF); // 25%
    delay(500);
    // change lamp colour to blue
    RGBLEDS.I2CWRITE6BYTES(ADDRESS, INTENSITY_RGB, 0x07ff, 0x07ff, 0x07ff); // Blue
    delay(500);
    RGBLEDS.I2CWRITE6BYTES(ADDRESS, INTENSITY_RGB, 0x0bff, 0x0bff, 0x0bff); // Blue
    delay(500);
    RGBLEDS.I2CWRITE6BYTES(ADDRESS, INTENSITY_RGB, 0x0fff, 0x0fff, 0x0fff); // Blue
    delay(500);
  // White, Silver, Gray, Black, Red, Maroon, Yellow, Olive, Lime, Green, Aqua, Teal, Blue, Navy, Fuchsia, Purple
    RGBLEDS.SETCOLOUR( White);
    delay(500);
    RGBLEDS.SETCOLOUR(Silver );
    delay(500);
    RGBLEDS.SETCOLOUR(Gray );
    delay(500);
    RGBLEDS.SETCOLOUR(Black );
    delay(500);
    RGBLEDS.SETCOLOUR(Red );
    delay(500);
    RGBLEDS.SETCOLOUR(Maroon );
    delay(500);
    RGBLEDS.SETCOLOUR(Yellow );
    delay(500);
    RGBLEDS.SETCOLOUR(Olive );
    delay(500);
    RGBLEDS.SETCOLOUR(Lime );
    delay(500);
    RGBLEDS.SETCOLOUR(Green );
    delay(500);
    RGBLEDS.SETCOLOUR(Aqua );
    delay(500);
    RGBLEDS.SETCOLOUR( Teal);
    delay(500);
    RGBLEDS.SETCOLOUR(Blue );
    delay(500);
    RGBLEDS.SETCOLOUR(Navy );
    delay(500);
    RGBLEDS.SETCOLOUR(Fuchsia );
    delay(500);
    RGBLEDS.SETCOLOUR(Purple );
    delay(500);
The cycle looks like this
Code is attached for your pleasure
Infineon.cpp.zip
Infineon.h.zip
6765.RGBLED.ino.zip
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to clem57 +3
    BY all means, feel free to reference all you like peter
  • turfgnome
    turfgnome over 11 years ago +1
    I have to say you are an great guy here, to post your codes on what I found to be the hardest component to find information about so soon. I will hopefully get my board today and test the codes I wrote…
  • fvan
    fvan over 11 years ago +1
    Well done Peter! Great work and so fast already!
    Robert Peter Oakes over 10 years ago in reply to e14 Contributor
    If you click on the main title i will take you to the full post, you should find them at the end of the post as downloadable attachments
    Peter
    e14 Contributor over 10 years ago in reply to fvan
    Where is the actual library.zip file?
  • matfur92
    matfur92 over 11 years ago
    Great job Robert Peter Oakes , thanks so much for sharing this solution! image
    DAB over 11 years ago
    Great job, Peter.
  • fvan
