Arduino
Arduino
Blog Can SIM808 GSM/GPRS+GPS Module, be integrated with Arduino?
  • Date Created: 11 Dec 2014 11:57 PM Date Created
  • Views 1458 views
  • Comments 6 comments
e14 Contributor
e14 Contributor
11 Dec 2014
Need some advice here. If not what other GSM/GPRS+GPS Module can work?
    e14 Contributor over 11 years ago in reply to clem57
    Okay, I got the details. I will now do my research.
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    Good, I understand the goals. Here are some possible high level approaches:
    • Bluetooth between Android app/phone and arduino. Plus side cheap and easy to do. Negative side must be close to each other to pair (15 meters open air).
    • Wireless between Android app/phone and arduino. Plus side still not too much cost and support easy to find. Range better but still within 25 meters. Negative would be setup phone each time you wish to use app(small pain).
    • GSM/CDMA between Android app/phone and arduino. Certainly range not a problem. But cost for using would need subscription to wireless carrier and would be like calling a number. Ugh in my mind.
    • Other???
    So you see some choices to make before going into the details. I suggest google each and weigh pros/cons of each. I just touched on the high level details.
    Cheers,
    Clem
    Thanks for responding Clem. Maybe a better understanding of what I am trying to accomplish will suffice. My project deals with reading voltage from a 9v Battery into an Android App. As you can see i'm a novice. All I have heard is that the Arduino is the best solution for a novice getting into programmable electronics. Therefore, if anyone can actually help me with the parts I need, (and maybe some instructions) little by little, I will figure out how to make it work. Of course, with the resources available on element 14.
    Truthfully, I am even uncertain about what you mean by a board solution.
    Thanks again.
  • clem57
    Oh! This is just a chip. Google for SIM808 and look for a board solution. image
    Thank you very much Clem. I have attached the link: http://www.aliexpress.com/store/product/SIM808-New-GSM-GPRS-GPS-Module-more-cheaper-than-SIM908-module-original-new-from-SIMCOM/605000_32246535788.html.
    How could this be integrated with an Arduino?
    Also, how do I get mobile cellular data to an App from an Arduino?
    What modules do I need?
    Does it have to be a module with a SIM card that sends voltage data to an App?
    Thanks again for responding. Any help will be greatly appreciated.
