Arduino
Arduino
Blog [Christmas Wreath of Things] Internet of Holiday Lights
  • Date Created: 16 Dec 2014 3:04 PM Date Created
  • Views 2023 views
  • Comments 7 comments
  • wreath_of_things
  • iot_holidaylights
16 Dec 2014
My entry for the Internet of Holiday Lights is an electro-mechanical wreath.
For those new to the subject: in Belgium, a wreath comes with four candles. Each advent Sunday we lit one of the candles.
The last Sunday of advent, all four candles are lit. The ceremony is documented on Wikipedia.
My electro-mechanical concept is going to be semi-intelligent, semi-dumb.
The candles will be leds or bulbs, and they won't have a clue about what week of the advent period it is. They will always be lit.
The lights will be hidden from the spectator's view by an opaque filter. The filter is fitting above the wreath and will be motor driven.
It has openings in it. These openings are positioned in such a way that either one, two, tree or four lamps are visible.
The smart part will be in the motor and its logic. Each day of the advent matches with a particular position of the filter. The motor driver will have to know what to do to put the motor in that given position.
The IoT magic takes care that the wreath knows what day it is. It's going to use a calendar service to get the date.
I don't know how to deal with time zones yet. Maybe solder in a particular resistor depending on what zone the owner is in?
In fact I don't know anything about te design yet. It's just an idea at this moment.
You'll find out together with me how it materializes.
    Jan Cumps over 11 years ago in reply to gadget.iom +2
    Turning on and off lights is a bit straightforward. I had this wild idea for some time now to make a steampunk-ish wreath design. I will now have to deal with complexities such as motor steering, position…
  • gadget.iom
    gadget.iom over 11 years ago in reply to Jan Cumps +2
    Both sides look pretty good. I now see what you thoughts are. The plan kinda reminds me of a particular design of circular junction box. http://www.tlc-direct.co.uk/Images/Products/size_3/AAJB20.JPG The…
    mcb1 over 11 years ago in reply to Jan Cumps +2
    I think its a great idea. As you said turning light on and off is easy. You could use a small magnet and Hall effect device for the position detection. Mark
    I will now have to deal with complexities such as motor steering, position determination, and all sorts of other problems that I can't predict yet. That will make it more interesting for myself.
    I've just drawn this pre-design on a beercard in Brussels airport:
    Backside image :
  • gadget.iom
    Just out of curiosity, what made you choose mechanical screening over lighting the LED's individually?
