Arduino
Arduino
Blog DIY spot welder stopped working
  • Author Author: Rowbow68
  • Date Created: 15 Jun 2024 8:32 AM Date Created
  • Views 1163 views
Rowbow68
Rowbow68
15 Jun 2024
Hello, I recently started putting together a diy spot welder made from microwave oven transformer and while I was waiting for some parts to be delivered I pretty much had the spot welder working and ready to put in the case I was going to use. So the unit was welding just fine but when i received the yxky welding pen I connected it and for a while I didn’t realize why the unit stopped working it just won’t weld and instead of making the unit better it completely did the opposite i completely dismantled it and couldn’t figure out what happened so I disconnected the trigger relay and plugged it directly to the transformer and it’s very strong spark but when I connect it back with the relay it just stops welding! Can anyone give me some advice on how to get it working if not I guess I can just use the welding pen without the relay and connect the separate trigger switch?   Please help!
    beacon_dave over 2 years ago
    Perhaps start by uploading a circuit diagram of how you have connected the trigger relay along with a photo of your actual set up.
    Are you actually using an Arduino for this (you have posted this in the Arduino section) ? If so, then you will need to upload your code listing .
