Arduino
Arduino
Blog Internet of Holiday Lights - We meet at Last
  • Date Created: 7 Jan 2015 8:22 PM Date Created
  • Views 1409 views
  • Comments 9 comments
  • interactive_tree
  • iot_holidaylights
e14 Contributor
e14 Contributor
7 Jan 2015
Ladies and gentlemen, engineers and hobbyists, welcome one and all to my first ever IoT project!
As you can probably guess, I am one of the lucky roadtesters for the Infineon RGB shield. Now this blog has been a long time coming, and I sincerely apologize for this delay, however unlike some other roadtesters this is my first ever electronics project(from home anyway) and so I was slightly unprepared. So I decided that it would be best to wait until I had pretty much everything that I needed for this project before blogging about it so that the blogs could be consistent and evenly spaced out but hey, better late than never as they say!
Now enough of the boring stuff, let's get down to business! So as you can probably see from my tag, I am going to create an interactive Christmas tree, which will be able to change it's lighting according to the mood of the room."How on earth will you find the 'mood' of a room?" I hear you cry! Well to be honest I'm not entirely sure however the plan is to use a small microphone(which will be hung from the Christmas tree itself) to listen to the sound in the room. The arduino yun will then change the colour, intensity and possibly even mode of the RGB strip according to what it hears. For example, if there is little noise the LEDs may be a dim red which will fade in and out, however if there is a lot of loud, high pitched noises the LEDs may be a bright flashing blue.
In terms of layout and setup etc., I will have the yun attached to the microphone, deciding on the mood of the room and then telling that to the uno which will control the Infineon board. Although i could possibly have this the other way round, I decided to use the yun to process the data as I also plan to possibly create an app for my phone using the android sdk which will allow me to change things like modes or intensity over wifi. My original thoughts were to connect the yun and arduino via usb, however this can produce some problems, such as the uno drawing power from the yun, and the fact that it looks extremely complicated! I will update you all on my final decision in my next blog.
Below is a picture showing all of the connections between the devices I will be using. It isn't too detailed, but it helps to show what on earth I'm rambling on about.
Join me again this time next week(hopefully) for my second blog, where i will working with the yun to turn the microphones outputs into moods and then send that to the uno.
    mcb1 over 11 years ago
    Jack
    Welcome the world of challenges where that great idea you had, needs to be turned into reality ... and there is that 'Oh my Gosh, what have i done" moment.
    Now that you have drawn you plan, tackle each section, and dont forget to search for similar projects that could give you a 'boost' (or most of the code image).
    From what I have observed, the members of this challenge and very supportive and happy to assist and share, so you are in good hands.
    e14 Contributor over 11 years ago in reply to Jan Cumps
    I'll have a play with different setups to see which is most effective and get back to you next time image
    I apologise I thought I read somewhere that pin 4 and 5 were being used. Thank you for that it really will make this a lot easier.
    Jan Cumps over 11 years ago in reply to e14 Contributor
    I did all on the Yun and gave the UNO to my kids image
    e14 Contributor over 11 years ago in reply to fvan
    There's no real reason it was more to offload the work from the yun to try to simplify things.
