Arduino
Arduino
Blog New to arduino and programming, 4x3 analog keypad question about making a passcode
  • Date Created: 10 Jan 2013 11:57 AM Date Created
  • Views 3717 views
  • Comments 21 comments
e14 Contributor
e14 Contributor
10 Jan 2013
Hi to you all.I am a 47 year old man who due to an accident am disabled and bought myself an Arduino to keep myself busy. I am  new to arduino and have written some basic sketches. and have made some nice projects. I have an UNO R3 board and I have made an analog keypad using 12 tactile buttons and 7 resistors with a 1nf capacitor to help with bouncing. i did this so that all my digital pins are free to use. My idea is to make an alarm system using 2 PIR sensors, 4 LED's, a buzzer and a siren.(I may want to add more components later) I have no problem in writing the code except for the 4x3 keypad. I want to make a passcode eg 1234 but this is the part I am struggling with. The push buttons return a value when they are pressed so how would I go about that part I have written code to serial print the code to my pc and give them a number. please see the code examples below but I have looked all over the internet and asked on the Arduino forum for some help with the keypad. If anyone can help I would appreciate it.
Thank you for taking the time to read this.
void readkeyboard(){
   keyboardValue = analogRead(keyboardPin); // read the value (0-1023)
   if (keyboardValue <25){keypressed = 0;}
   if ((keyboardValue >25) && (keyboardValue < 67)){keypressed = 1;}
   if ((keyboardValue >67) && (keyboardValue < 108)){keypressed = 2;}
   if ((keyboardValue >108) && (keyboardValue < 162)){keypressed = 3;}
   if ((keyboardValue >162) && (keyboardValue < 253)){keypressed = 4;}
   if ((keyboardValue >253) && (keyboardValue < 361)){keypressed = 5;}
   if ((keyboardValue >361) && (keyboardValue < 479)){keypressed = 6;}
   if ((keyboardValue >479) && (keyboardValue < 619)){keypressed = 7;}
   if ((keyboardValue >619) && (keyboardValue < 765)){keypressed = 8;}
   if ((keyboardValue >765) && (keyboardValue < 819)){keypressed = 9;}
   if ((keyboardValue >819) && (keyboardValue < 899)){keypressed = 0;}// this is the * key
   if ((keyboardValue >889) && (keyboardValue < 955)){keypressed = 0;}
   if (keyboardValue >965){keypressed = 0;}  // this is the # key
when the keys are pressed they return these values
1=58, 2=96, 3=145,   4=228,  5=335,  6=447, 7=598,  8=720,  9=809,  *=890,  0=941, #=970
I have Written to the buttons like this just to test the keypad works as it should
   if (keyboardValue >25 && keyboardValue < 67) digitalWrite (12,HIGH);
   if (keyboardValue >67 && keyboardValue < 130) digitalWrite (11,HIGH);
   if (keyboardValue >162 && keyboardValue < 253) digitalWrite (9,HIGH);
   if (keyboardValue >108 && keyboardValue < 162) digitalWrite (10,HIGH);
   if (keyboardValue >253 && keyboardValue < 361) digitalWrite (8,HIGH);
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +1
    Get some sleep and check out http://www.oomlout.com/a/products/ardx/ tomorrow.
    Hi again. I have rewritten the code to try and sort out my problems. I have stopped the keypad returning conatant zeros but i still cannot get the password to work. Hopefully one of you will be able to help me with that. I can manage the rest of it.
    Thank you.
    Jeremy
    int i, k, pwcount=0;
    char password[]="1234",entry[10];// password that is stored
    int buttonPin=0;// keypad pin
    int val;// value of key pressed
    int PIR=12;//PIR sensor power pin
    int senseValue;// value of PIR sensor pin
    int nos;// variable for number of the keypad
    int sensePin=1;//Pin PIR is connected to
    int buzzerPin=2;// buzzer connected here
    int led3=3;// leds for testing
    int led4=4;
    int led5=5;
    int led=13;
    void setup() {
    pinMode (buttonPin,INPUT);
    pinMode (sensePin,INPUT);
    pinMode(PIR,OUTPUT);
    pinMode (led,OUTPUT);
    pinMode (led3,OUTPUT);
    pinMode (led4,OUTPUT);
    pinMode (led5,OUTPUT);
    pinMode (buzzerPin,OUTPUT);
    Serial.begin(9600);
    void loop() {
       for (i=0; i<=1; i++){
      reset();
      val=analogRead(buttonPin);
      val = map(val, 0, 1023, 0, 255);
    // Serial.print("Button Value   ");//used for debugging
    //Serial.println(val);
    senseValue=analogRead(sensePin);
    senseValue = map(senseValue, 0, 1023, 0, 255);
    //Serial.print("     Sensor Value   ");
    //Serial.println(senseValue);
    //delay(200);
    if((val>10&&val<17)){(nos=1);//read the keypad
    blinker();
      if( nos==1){
       entry[pwcount]='1' ;//returns the button press
       pwcount++;
       delay(250);
    Serial.print('1');//prints the key value for debugging
    if((val>20&&val<29)){(nos=2);
      blinker();
      if( nos==2){
       entry[pwcount]='2' ;
       pwcount++;
       delay(250);
    Serial.print('2');
    if((val>31&&val<38)){(nos=3);
      blinker();
      if( nos==3){
       entry[pwcount]='3' ;
       pwcount++;
       delay(250);
    Serial.print('3');
    if((val>50&&val<58)){(nos=4);
      blinker();
      if( nos==4){
       entry[pwcount]='4' ;
       pwcount++;
       delay(250);
    Serial.print('4');
    if((val>75&&val<88)){(nos=5);
       blinker();
      if( nos==5){
       entry[pwcount]='5' ;
       pwcount++;
       delay(250);
    Serial.print('5');
    if((val>101&&val<115)){(nos=6);
      blinker();
      if( nos==6){
       entry[pwcount]='6' ;
       pwcount++;
       delay(250);
    Serial.print('6');
    if((val>138&&val<150)){(nos=7);
      blinker();
      if( nos==7){
       entry[pwcount]='7' ;
       pwcount++;
       delay(250);
    Serial.print('7');
    if((val>170&&val<180)){(nos=8);
      blinker();
      if( nos==8){
       entry[pwcount]='8' ;
       pwcount++;
       delay(250);
    Serial.print('8');
    if((val>195&&val<202)){(nos=9);
      blinker();
      if( nos==9){
       entry[pwcount]='9' ;
       pwcount++;
       delay(250);
    Serial.print('9');
    if((val>219&&val<226)){(nos=10);
       blinker();
      if( nos==10){
       entry[pwcount]='*' ;
       pwcount++;
       delay(250);
    Serial.print('*');
    if((val>230&&val<238)){(nos=11);
      blinker();
      if( nos==11){
       entry[pwcount]='0' ;
       pwcount++;
       delay(250);
    Serial.print('0');
    if((val>238&&val<245)){(nos=12);
       blinker();
      if( nos==12){
       entry[pwcount]='#' ;
       pwcount++;
       delay(250);
    Serial.print('#');
    pwcount=0;
      for(k=0; k<=5; k++){//if the passwords match this part does not work
       if(k==5){
      Serial.println("Alarm Disabled");
       digitalWrite(3, HIGH);
       digitalWrite (4, LOW);
       digitalWrite (13,LOW);
       digitalWrite(PIR,LOW);
       break;
       if(password[k] != entry[k]){// if the passwords do not match
         digitalWrite (4, HIGH);
        // Serial.println("Alarm ON 2 Seconds Until Armed");
         digitalWrite(3,LOW);
          break;
         armed();
         //delay(2000);
         //digitalWrite (13,HIGH);
         break;
      // k<10
      for(k=0; k<10; k++)
      entry[k]=0;
    void reset(){
       int j;
       for(j=0; j<=1; j++)
       analogWrite(j,LOW);
    void blinker(){// blinks the led for confirmation of button press
      digitalWrite(13, HIGH);
      delay(15);
      digitalWrite(13, LOW);
    void printing(){
    delay(200);
    void armed (){
      delay(100);
      digitalWrite(13,HIGH);
      digitalWrite(PIR,HIGH);
        Serial.println("Alarm Enabled");
         printing();
         Serial.println("Callibrating System Please wait..");
         printing();
         Serial.println("System Activating...");
         printing();
         Serial.println("All Systems Functioning Correctly");
          printing();
           delay(500);
         Serial.println("Alarm On");
    void triggered(){
      digitalWrite(buzzerPin,HIGH);
      digitalWrite(13,LOW);
      delay(30);
      digitalWrite(buzzerPin,LOW);
      delay(30);
    Hi Billabott. I have made the changes as you have shown. The ldr should have been PIR for my motion sensor..( I hve changed that now) I will comment my sketch more to make it easier to read.
    The code keeps on looping I think because the keypad returns a constant 0 value from the analog pin. I want to make some code to ignore the value 0 but I cannot make it do that.
    Thanks for looking at it for me though
    Jeremy
  • billabott
    After looking at an official arduino.cc example of using analog input ports, I can safely recommend several changes to your code.
    As far as I know, A0 and A1 are just undefined variables and as such are of no value in configuring the analog pins.
    int buttonPin=0;                  //  here
    int val;                              // here
    int ldr=12;        // what the heck is this?  You Need a Whole Lot more comments documenting your intent
    int senseValue;                 // here
    int led=13;
    int sensePin=1;                   //here
    Thank you billabott I would appreciate that.
    Jeremy
  • billabott
    The usual way to handle the sequencing of actions in the code is via a "state machine".  Will have time to look at your code tomorrow unless someone else pipes in.
