Arduino
Arduino
Blog Portlet (the Programmable Outlet controlled by Arduino)
  • Author Author: ThornTech
  • Date Created: 15 Nov 2014 11:41 PM Date Created
  • Views 1276 views
  • Comments 5 comments
ThornTech
ThornTech
15 Nov 2014
Hi all,
I'm trying to raise some funds for the Portlet project on Kickstarter:
https://www.kickstarter.com/projects/65790393/portlet-the-programmable-outlet
The brain is an Arduino Pro and it's sporting 2 relay controlled outlets, 2 thermocouple inputs, 4 buttons, the reset button, and an LCD screen.
Here's a list of some project ideas using the Portlet:
http://www.mechtechlab.com/wiki/portlet-2/portlet-uses/
Thanks for taking a look!  Hope it generates some interest.
  • michaelkellett
    michaelkellett over 11 years ago in reply to ThornTech
    Yes it does - thanks.
    Sounds fine.
    Good luck with the UL approval.
    MK
  • ThornTech
    ThornTech over 11 years ago in reply to michaelkellett
    Hey Michael!
    All of the low voltage components are on a completely separate PCB from the mains; connected by a cable that only runs 5V.  On the high power board there is module that converts 120 VAC to 5 VDC (that module is off the shelf nad has already been UL approved and safety tested; I didn't want to risk designing it myself).
    Does this answer your question?
  • michaelkellett
    michaelkellett over 11 years ago in reply to Robert Peter Oakes
    Sorry Peter, that doesn't answer my (intended) question - what I want to know is how the low voltage side gets isolated power from the mains. I couldn't see a transformer anywhere which is why I'm asking.
    MK
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to michaelkellett
    Solid State Relays where used in the prototypes, I would assume but not guarantee this is continued in the production version
  • michaelkellett
    How is the low voltage side isolated from the mains ?
    MK
