Arduino
Arduino
Blog RGB LED Shield diagrams for documentation purposes
  • Author Author: shabaz
  • Date Created: 17 Dec 2014 3:36 PM Date Created
  • Views 4941 views
  • Comments 22 comments
  • infineon
  • iot_holiday_lights
  • yun
  • light_emitting_diode
  • diode
  • holiday
  • iot_holidaylights
  • light
  • light-emitting-diode
  • emitting
  • led
  • rgb
  • iot-holiday-lights
  • arduino-yun
  • lights
  • infineon_led
  • iot
  • arduino_shield
  • shield
  • arduino_yun
  • arduino-shield
shabaz
shabaz
17 Dec 2014
For those creating projects with the RGB LED ShieldRGB LED Shield, hopefully these images can come in handy.
They are attached to the bottom of this post in two versions - white background and transparent background.
I can't take credit for the Arduino Uno diagram, I found that on the Internet (not sure of the original source, it was in many places - and just edited it slightly).
rgb-shield-vector-emf.zip
rgb-shield-vector-svg-inkscape.zip
    shabaz over 11 years ago in reply to RParkerE +4
    Hi Parker, Can you try the program called RGBLED_2_SAFE.ino ? I tried that, with LEDs connected to the red channel only, and they worked, see the post here: RGB LED Shield from Infineon - Getting Started…
  • Workshopshed
    Workshopshed over 11 years ago in reply to lokkytron +3
    Yes that file did not seem to have anything to hookup to. But shabaz 's Inkscape file worked once I deleted the big white rectangle from it.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +3
    I do not beleive there is a minimum current limit for the Infineon board, it is simply the set constant current in the demo sketch, the board is actually programable for almost any current up to the MAX…
  • 4ringfan
    4ringfan over 11 years ago in reply to Workshopshed
    It's experimental, but you could give it a shot.
    Online SVG image converter
  • Workshopshed
    Hi shabaz do you have the Infinion RGB shield in a vector format? I'm trying to get it into Fritzing and Fritzing is not playing nicely with bitmaps and wants a SVG.
