Arduino
Arduino
Blog Running CP/M (yes, the 80's operating system) on the Arduino DUE
  • Author Author: marcelodantas
  • Date Created: 10 Dec 2014 5:13 PM Date Created
  • Views 2233 views
  • Comments 6 comments
  • cp/m
  • emulation
  • z80
  • due
marcelodantas
marcelodantas
10 Dec 2014
Hi everyone,
I have succeeded running (to some extent) CP/M 2.2 on the Arduino DUE, using code from my project at http://runcpm.blogspot.com/
Now I am stuck at the file system part of the project. I am having a hard time dealing with the SD card routines. I am fairly new to the Arduino environment, and debugging is not a strong point of their IDE, so maybe someone wants to help me out?
I would gladly share the source code to anyone willing to provide some guidance.
The Z80 emulation already works fine, and some applications like mbasic are loading and running fine (technically I am already running Microsoft's mbasic on an Arduino), but obviously, when any disk access is needed, things go deeply South.
Any help is much appreciated.
Cheers,
Marcelo.
  • marcelodantas
    marcelodantas over 11 years ago in reply to e14 Contributor
    Hi Denis,
    Sorry for taking so long to reply.
    Seems that the version of the library you have doesn't match the one I have.
    I will check the project and see what's there, it has been a long time since I touched those sources.
    In the meantime, and if you read this message, please get in touch with me on my gmail account ... marcelo.f.dantas ...
    I am not visiting this forum as often as I would like to, so going through my gmail would be a better way of getting in touch.
    Let's make CPMDuino work on your DUE.
    Cheers,
    Marcelo.
    Hi,
    Sorry if i write to you, but i have a question about running CPM on the Arduino DUE.
    I downloaded all the files on GitHub, and i use ide 1.5.2 with the SDfat library, but the compile returns this error: class SdFile has no member named getFilename.
    Is the worth library ? Can you send me the lib please?
    Sorry for this, but i really want to run CPM on my DUE... I also made the Grant Searle CPM Z80 machine, and works fine, so i'd like to put them together and see the difference.
    Thanks for all
    Denis (from Italy)
  • marcelodantas
    marcelodantas over 11 years ago in reply to DAB
    Hi DAB,
    All the CP/M stuff is working, this is based on my other project, RunCPM (http://www.sourceforge.net/projects/runcpm/), it is the Arduino part that is giving me a headache.
    So far most of it is working, I just need to fix some quirk on the directory manipulation routines.
    Other than that, if you feel like running Microsoft Basic 80 again, please give it a try. And let me know how it goes.
    To build and run it needs the SdFat library, and a shield with a SD card.
    It will run on the Arduino DUE, as it is the only I could find with enough RAM to hold the emulation, but the code could be easily adapted to use external RAM as well.
    Keep in touch.
    Cheers,
    Marcelo.
  • marcelodantas
    marcelodantas over 11 years ago in reply to amgalbu
    Awesome!
    I have fixed most of the issues and uploaded the source code to Sourceforge (http://sourceforge.net/projects/cpmduino).
    If you have an Arduino DUE with SD card shield you can download it and give it a try.
    Cheers,
    Marcelo.
    DAB over 11 years ago
    Hi Marcelo,
    Using CPM takes me back a few decades.
    First, the file format is very different for CPM than the current formats used for today's storage devices.
    Do you have any references for the CPM format?
    I will look in my library, but I am not sure I have anything on the format, but I will look.
    I do remember that there were a number of disk controller chips used in those days, which could also make many different formats.
    There used to be a couple of CPM websites, but again, I have not looked for such things for a lot of years.
