Arduino
Arduino
Blog Send email with photo on movement - The smart entrance - Internet of Holiday Lights RoadTest
  • Author Author: matfur92
  • Date Created: 23 Jan 2015 1:36 AM Date Created
  • Views 882 views
  • RoadTest
  • enchanted_rc
  • holiday
  • iot_holidaylights
  • smart_entrance
  • christmas
  • iot
matfur92
matfur92
23 Jan 2015
(prev. post is Get a working webcam on Arduino Yun - The smart entrance - Internet of Holiday Lights RoadTest read this to have a working webcam on Arduino Yun)
In this post I will explain how to start a python script or possibly any other program / bash by our Arduino sketch Yun.
In particular, I am going to explain the procedure to have a motion detector (using a HC RS04 ultrasound sensor) that allows to send a photo by email in case it detects a change of distance of at least 2cm in two successive measurements in 'arc of about 60ms.
So let's see what are the steps necessary to accomplish this purpose.
Get a working python with support to HTTPS/SSL doing in SSH :
opkg update                      #updates the available packages list
opkg install distribute          #it contains the easy_install command line tool
opkg install python-openssl      #adds ssl support to python
I have positioned the sendemail.py (download it from attached file) in the /www/cgi-bin with FileZilla. [sendemail.py taken from http://dev.mikamai.com/post/76945627390/you-cant-touch-this-an-evil-arduino-based]
The sendmail.py was edited with my email ad login parameters of gmail.
IMPORTANT : go to https://www.google.com/settings/security/lesssecureapps and enable this option to have a working script!!
This is the script that I have loaded in my Arduino Yun that send an email when the distance have a delta > 2cm.
#include <Bridge.h>
#include <Wire.h>
//HC RS04 ultrasound sensor
int triggerPort = 4;
int echoPort = 2;
Process p;
void setup() {
    Wire.begin();
    Bridge.begin();
    Serial.begin(115200);
    //ultrasound sensor
    pinMode( triggerPort, OUTPUT );
    pinMode( echoPort, INPUT );
void commandGetImage(int n){
  p.runShellCommand("fswebcam --device /dev/video0 --resolution 640x480 --jpeg 95 --save /www/"+String(n)+".jpg --palette MJPEG --no-banner"); //takes the picture
  while(p.running()); //wait till the process ends
float getDistance(){
  digitalWrite( triggerPort, LOW );
  //send one impulse of 10microsec on trigger
  digitalWrite( triggerPort, HIGH );
  delayMicroseconds( 10 );
  float duration = pulseIn( echoPort, HIGH );
  float centimeter = 0.034 * duration / 2;
  if( duration > 58000 ){
    duration=-1;
    centimeter=-1;
  if (centimeter==0){
    Serial.println("ERROR - 0 cm - get again the distance");
    delay(10);
    centimeter=getDistance();
  return centimeter;
void loop() {
    float d,prev=getDistance();
    float delta=0;
    while (true){
        delta=0;
        //get the first distance
        prev=getDistance();
        //get the image
        commandGetImage(0);//0.jpg is the image file taken
        //wait 50ms
        delay(50);
        //get the second distance
        d=getDistance();
        //calculate the delta
        delta=abs(d-prev);
        //if the delta is big send email - a movement is recognised!
        if(delta>2){
           Serial.print(" delta= "+String(delta) + "["+String(prev)+"cm,"+String(d)+"cm]");
           Serial.print("\nSENDING...");
          p.runShellCommand("python /www/cgi-bin/sendemail.py /www/" +String(0)+".jpg"); //sends the picture via email
          Serial.println("E-MAIL SENDED");
        }else{
          Serial.print(".");
          delay(50);
sendemail.py.zip
  • matfur92
    matfur92 over 11 years ago in reply to ipv1
    Thanks for the suggestion, but I was already awareimage I did not deliberately used that guidance, it was not my purpose.
  • ipv1
    ipv1 over 11 years ago
    You might also find it useful to visit this link
    https://www.google.co.in/url?sa=t&source=web&rct=j&ei=GrLBVOTxA4mX8QWmv4DwBA&url=https://learn.adafruit.com/wireless-security-camera-arduino-yun/introduction&ved=0CBsQFjAA&usg=AFQjCNFb4adPdqBLyjRCqHoeOeUQJA4gdg&sig2=tALnE2seGhbCnhNcfDKN9w
    Its an Adafruit tutorial on using temboo to send images to drop box. Its actually pretty simple.
