Arduino
Arduino
Blog Speech Recognition with BitVoicer, Arduino and a Microphone
  • Date Created: 27 Dec 2012 1:43 PM Date Created
  • Views 3625 views
  • Comments 9 comments
  • speech_recognition
  • voice_recognition
e14 Contributor
e14 Contributor
27 Dec 2012
In this project I use BitVoicer’s speech recognition features (http://www.bitsophia.com/BitVoicer.aspx), one Arduino board and one electret microphone (https://www.sparkfun.com/products/9964) to control a few LEDs.
The following fritzing schematic shows how I wired my Arduino board:
I’m also adding a few pictures and a YouTube video of the project running.
Unfortunately, the sketch I wrote for my first post is no longer supported by the new version of BitVoicer. Here is the new sketch:
#include <BitVoicer11.h>
//Instantiates the BitVoicerSerial class
BitVoicerSerial bvSerial = BitVoicerSerial();
//Stores true if the Audio Streaming Calibration tool
//is running
boolean sampleTest = false;
//Stores the data type retrieved by getData()
byte dataType = 0;
//Sets up the pins and default variables
int pinR = 3;
int pinY = 5;
int pinG = 6;
int lightLevel = 0;
void setup()
  //Sets the analog reference to external (AREF pin)
  //WARNING!!! If anything is conected to the AREF pin,
  //this function MUST be called first. Otherwise, it will
  //damage the board.
  bvSerial.setAnalogReference(BV_EXTERNAL);
  //Sets up the microcontroller to perform faster analog reads
  //on the specified pin
  bvSerial.setAudioInput(0);
  //Starts serial communication at 115200 bps
  Serial.begin(115200);
  //Sets up the pinModes
  pinMode(pinR, OUTPUT);
  pinMode(pinY, OUTPUT);
  pinMode(pinG, OUTPUT);
void loop()
  //Captures audio and sends it to BitVoicer if the Audio
  //Streaming Calibration Tool is running
  if (sampleTest == true)
    //The value passed to the function is the time
    //(in microseconds) that the function has to wait before
    //performing the reading. It is used to achieve about
    //8000 readings per second.
    bvSerial.processAudio(46);
  //Captures audio and sends it to BitVoicer if the Speech
  //Recognition Engine is running
  if (bvSerial.engineRunning)
//This function runs every time serial data is available
//in the serial buffer after a loop
void serialEvent()
  //Reads the serial buffer and stores the received data type
  dataType = bvSerial.getData();
  //Changes the value of sampleTest if the received data was
  //the start/stop sampling command
  if (dataType == BV_COMMAND)
      sampleTest = bvSerial.cmdData;
  //Signals BitVoicer's Speech Recognition Engine to start
  //listening to audio streams after the engineRunning status
  //was received
  if (dataType == BV_STATUS && bvSerial.engineRunning == true)
    bvSerial.startStopListening();
  //Checks if the data type is the same as the one in the
  //Voice Schema
  if (dataType == BV_STR)
    setLEDs();
//Performs the LED changes according to the value in
//bvSerial.strData
void setLEDs()
  if (bvSerial.strData == "wake")
    digitalWrite(pinR, LOW);
    digitalWrite(pinY, LOW);
    digitalWrite(pinG, LOW);
    digitalWrite(pinR, HIGH);
    digitalWrite(pinY, HIGH);
    digitalWrite(pinG, HIGH);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "sleep")
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "RH")
    lightLevel = 255;
  else if (bvSerial.strData == "RL")
    lightLevel = 0;
  else if (bvSerial.strData == "YH")
    lightLevel = 255;
  else if (bvSerial.strData == "YL")
    lightLevel = 0;
  else if (bvSerial.strData == "GH")
    lightLevel = 255;
  else if (bvSerial.strData == "GL")
    lightLevel = 0;
  else if (bvSerial.strData == "ALLON")
    lightLevel = 255;
  else if (bvSerial.strData == "ALLOFF")
    lightLevel = 0;
  else if (bvSerial.strData == "brighter")
    if (lightLevel < 255)
      lightLevel += 85;
      analogWrite(pinR, lightLevel);
      analogWrite(pinY, lightLevel);
      analogWrite(pinG, lightLevel);
  else if (bvSerial.strData == "darker")
    if (lightLevel > 0)
      lightLevel -= 85;
  else
    bvSerial.sendToBV("ERROR:" + bvSerial.strData);
The BitVoicer Voice Schema I used can be downloaded from: http://www.justbuss.xpg.com.br/BitVoicerTest2.zip (you need to have BitVoicer installed to be able open it).
Now I want to control a few things (lights and ceiling fan) at home. Suggestions on how to connect them to the Arduino are very welcome.
    e14 Contributor over 11 years ago +2
    ... and my idea ended up on Kickstarter! https://www.kickstarter.com/projects/310865303/movi-a-standalone-speech-recognizer-shield-for-ard Just wanted to feed that back given it all started here a while…
    e14 Contributor over 11 years ago in reply to shabaz +2
    Yes, it's my Kickstarter and thanks for the very good questions! There is nothing stopping you from using Rasberry PI (or another SBC) and installing open source speech recognition software -- except the…
    DAB over 13 years ago +1
    Impressive demonstration. I hope this blog gets some people moving toward voice activated home automation. Just a thought, DAB
    There is nothing stopping you from using Rasberry PI (or another SBC) and installing open source speech recognition software -- except the fact that this is a quite complex task. I have been working in speech for quite some time and unless you know how to fiddle with acoustic models, language training, phonetization and other issues, stuff can get hairy pretty quickly. Jasper (https://jasperproject.github.io/) has been offering this sort of integration work as a download for Rasberry PI, except their speech recognition quality is not up to par. They only offer keyword recognition and after about 20 different keywords, accuracy went down the drain when I tried it. Then, there is no hardware integration. So Jasper ends up recommending concrete microphone setups. Just installing Jasper on a PI takes a couple of days of work. What you'll get for the $80 in MOVI is something you plug onto the Arduino and just works. It has a microphone and automatics gain control on there and fits neatly into the Arduino programming environment. It's open source anyways, so can still fiddle around if you want to.
    shabaz over 11 years ago in reply to e14 Contributor
    Is it your kickstarter, or someone else's?
    From what I can tell, the board has a SOM running Linux. It made me wonder, why not just use a Raspberry Pi (or other SBC) running open source speech recognition software. It would be far cheaper compared to the $80 that the Kickstarter board costs, and no need to wait until February 2016 (or 2017 if it gets delayed by a year like many Kickstarter projects). What benefit does it have compared to using a Raspberry Pi for this application?
    The RPI A+ is $25 I think..
    Just wanted to feed that back given it all started here a while ago.
  • clem57
    clem57 over 11 years ago
    Oldie but goodie!
    Clem
    I just had a completely different idea: https://sites.google.com/site/asrshield/
