Arduino
Arduino
Blog Well.. I found the problem W/ RGB LED
  • Date Created: 27 Mar 2015 2:21 AM Date Created
  • Views 1381 views
  • Comments 10 comments
e14 Contributor
e14 Contributor
27 Mar 2015
I was working on a project for my UNO that would randomly fade in and out the RGB and make different colors.. After troubleshooting.. I find that the green portion of the RGB LED is not working..
I tested it with a pretty well used 3.3 v watch battery. The red and blue work fine..
Since they closed the local Radio Shack.. I will have to order some I guess..
  • neilk
    neilk over 11 years ago +2
    mikejn1 I'm in UK and find eBay is a fantastic source of components at very reasonable prices - I got all my LEDs, including RGB ones from suppliers on eBay.
  • ejohnfel
    ejohnfel over 11 years ago in reply to e14 Contributor +2
    It is, but I feel I should also mention, sometimes you get what you pay for. Some of the things can be of questionable quality. So when you need something critical or important, its best to source the…
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    It could also be that you dont have enough volts for the green LED, there is some variance between models from 2V up to in excess of 3.2V so as your using a 3V3 watch battery it may well be the issue
  • neilk
  • ejohnfel
    I also feel your pain regarding RadioShack. They were always the "goto" place when you needed parts in a pinch.
    e14 Contributor over 11 years ago in reply to ejohnfel
    That stinks..The red and blue parts of the LED worked just fine in the circuit, just no green..
  • ejohnfel
    Sorry to hear, I had a friend that spent a week trying to find out why his RGD LED wasn't working... he was sure it was his code, and even though he eventually figured out he had damaged the LED, he also discovered that it was common anode LED and not a common cathode as he thought it was.
