Arduino Forum Make my own female to female cables for Arduino
  • Subscribers 403 subscribers
  • Views 448 views
  • pins
  • female
  • crimp
SGarciaV
SGarciaV over 10 years ago
Hi all,
I am going to need 18" cables with female header connectors on both ends. I plan to purchase some ribbon cable, crimp on female header connectors and plastic connector hoods. I would like to ask all of you for help in identifying the correct components that I need to order. The last time I did so I ended up with crimp pins that were too big for the headers.
Are the following items the correct size?
Female Crimp Pins for 0.1" Housings 50-Pack | 1930 | Pololu
http://www.hobbytronics.co.uk/crimp-conn-housing-1
or if I need the pins to be contiguous:
http://www.hobbytronics.co.uk/crimp-conn-housing-4
I am in the US, so eventually I would purchase from a US supplier. The above links are just to identify the correct items.
Thank you! Salvador
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +1
    The parts look good but it is alot of hasstle onsidering you can get this for 5$ including shipping from EBay
  • SGarciaV
    SGarciaV over 10 years ago in reply to mcb1 +1
    No way I would have ever known the use of "cm". I just parroted the text used in the descriptions on eBay. Thanks.
    40Pcs 1P 2.54mm to 2P 2.0mm Female to Female Jumper Cables Wire 40cm for Arduino
  • SGarciaV
    SGarciaV over 10 years ago in reply to Robert Peter Oakes
    Thanks! Yeah, I saw some extra log f-f cable, but he longest I saw was 30cm and I need at least 45cm (max 50cm).Not having found any ready made cables of that length prompted me to include the option of making my own. Regards, Salvador
    mcb1 over 10 years ago in reply to SGarciaV
    I have seen M-F so with some glue to join them together, you could easily achieve the 500mm
    (BTW cm is a dress makers unit image... lets stick to Engineering standards and use mm or m as per the standards.)
  • SGarciaV
