Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 69757 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    Yes it's totally possible.  I have code samples relating to that in my 10th tutorial video.
    hola tengo un problema necesito hacer un control automatico con joystick que me  recomiendan por donde empiezo muchas gracias un saludo
  • sciguy14
    Que es la proyecta?  Necesita un joystick analógico o digital?
  • billabott
    billabott over 15 years ago in reply to e14 Contributor
    Sí, explique por favor sobre su proyecto.  El Arduino y el Lauchpad con los convertidores del A/D pueden procesar señales de la palanca de mando análoga.
    También considere: http://arduino.cc/blog/category/ic/adc/
  • Ikana
    Ikana over 15 years ago in reply to e14 Contributor
    @billabott yo estoy haciendo algo muy parecido uso el joystin analogico de un control de xbox 360 ii me comunico con el arduino por serial usando c++.
  • Ikana
    i would like to konow how much data i can send over and xbee and if there is an function on the arduiono laguage to convert betwn hexadecimal and decimal thx XD
  • billabott
    billabott over 15 years ago in reply to Ikana
    here
  • sciguy14
    sciguy14 over 15 years ago in reply to Ikana
    As much data as you want.  You are only limited by the transmission speed.  The print() function converts types well: http://www.arduino.cc/en/Serial/Print
    Hi!
    Ich bin gerade dabei mir ein Rack zusammenzustellen. Ich habe zwei Probleme: Ich möchte mir dafür einen Power Conditioner von Samson (Powerbrite pb10 PRO). Dieser Conditioner hat 8 Kaltsteckerausgänge. Nun habe ich in meinem Rack aber auch ältere Geräte, bei denen das Kabel noch befestigt ist, und nicht wie bei neueren Geräten nicht fest ist. Bei den entsprechenden Geräten handelt es sich um ältere rackmount Verstärker von Marshall. Nun möchte ich gerne wissen, ob ich die "normalen" Stecker auch via Adapter in die Kaltgerätebuchse stecken kann, ohne, dass mir gleich alles um die Ohren fliegt.
    Mein zweites Problem betrifft ein Gerät aus der Niederlande. In Holland haben Sie 220V in den Steckdosen. Ich hab in meinen Steckdosen jedoch 230V. Ist das ein Problem in Sachen Sicherheit und Funktionalität, oder wird es einfach ein bisschen heiss, läuft aber trotzdem einwandfrei?
    Grüsse Arcainis!
  • driggs
    driggs over 15 years ago
    Jeremy,
    I know that you can use an arduino to send an sms message through a cms cell phone to another phone for auto- texting. Can you do the same thing with a cdma phone(like verizon droid)?
    thanks,
    dennis
    driggs12000@yahoo.com
