Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 70179 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
    Hello Jeremy and thanks for this postimageimage
    i need your help because i don't know if muy project is possible
    i would like to trigger a camera with arduino and a IR sensor but this trigger must be done 18 i/s
    that is:
    an IR sensor will be activated 18 times in a second. Each activation will trigger the camera via Arduino.
    is this possible?
    is there a no so much expensive camera who supports this?
    thanks a lot
    Jeremy, I'm really enjoying your tutorials...I am completely new to the arduino or any programing for that matter.  I was wondering if I have an idea of what I want the arduino to do, is there a place where I can virtually build what I want online.  This way I can visually see how things will go together and what I need to order.  Or is there some where I can go to have someone tell me what I need and how to build it.  Thanks for all your help and I really appreciate you taking your time to help everyone!...Jeffrey
    e14 Contributor over 15 years ago in reply to tronixstuff
    ThankUimage
  • WestfW
    WestfW over 15 years ago in reply to e14 Contributor
    i would like to trigger a camera  with IR sensor [to be] activated 18 times in a second. Each activation will trigger the camera via Arduino.
    The Arduino is easily capable ot handling 18 events a second, but there are very few cameras that can be activated that frequently (there are very few still cameras that will take 18 pictures per second, even when activated in "continuous shooting" mode.  Not counting video, which is normally much lower resolution.)
  • wb8nbs
    wb8nbs over 15 years ago in reply to WestfW
    I am no expert, but perhaps a video camera arranged for Stop Motion?
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    There could be a number of reasons why that would happen.  Have you tried forcing it with the -F option?
  • sciguy14
    You need to map the 0-5V values first from 0-1023.  If 0V is 0, and 5V is 1023, then 2V is 409.
    You would read the values, then compare:
    if (analogRead(0) < 409) {
    digitalWrite(2, HIGH);
    digitalWrite(3, HIGH);
    digitalWrite(4, LOW);
    digitalWrite(5, LOW);
    else{
    digitalWrite(4, HIGH);
    digitalWrite(5, HIGH);
    digitalWrite(2, LOW);
    digitalWrite(3, LOW);
  • sciguy14
    You are not going to find a cheap camera that supports that.  You'd be better of with a video camera.
  • sciguy14
    Not that I've used... You can put a schematic together first that will help you to visualize things...
    I'm in the proceess of making a fight stick from a wired 360 controller. How to I connect the Left and Right Triggers to Sanwa push buttons? I'm using a MadCatz wired controller.
