Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 70170 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • wb8nbs
    wb8nbs over 15 years ago in reply to sciguy14
    I am interested in RS485 as well, would like to wire up an Arduino compatible LAN around the house.  Doesn`t anybody make an affordable shield using one of those chips?
  • sciguy14
    sciguy14 over 15 years ago in reply to wb8nbs
    RS-485 is NOT the same as ehternet, so be careful.  They both utilize the RJ-45 connector type but are entirely different protocols.  If you want to put an arduino on your LAN, you should get the arduino ethernet shield.
  • wb8nbs
    I'm looking for cheap.  I don't need ethernet to monitor my sump pump.
  • sciguy14
    You'd need to make your own shield with that chip then.
  • terryking
    terryking over 15 years ago in reply to wb8nbs
    Hi, Here's an RS485 "Electronic Brick" which usesa 4 pin connector for +5, Gnd, Xmit, Rcve  and another pin for Bus Direction. It has two 3-pin connectors for bus in and bus out, with + and - data and Gnd.  http://arduino-direct.com/sunshop/index.php?l=product_detail&p=63
    There is some incomplete information here: http://arduino-info.wikispaces.com/RS485-Brick  (which I have not finished translating, so the later part is still quite Chinglish..). Hope to finish this up soon... and add photos.. I'll try to find an image now... (see below for 3 Arduinos networked)..
    This will be a continuing Arduino product in my shop, and the developer is considering a version with different RS485 bus connectors.. If anyone has suggestions on this, please let me know..
    RS485 with a decent protocol would be a good low-overhead low-cost (These are $6.50 per node) solution.
    I plan to show a Home Automation application using these...
    Regards, Terry King
    ...In The Woods In Vermont
    terry@yourduino.com
    Hi Jeremy,
    I have a question about using an arduino as an avrisp programmer. I am trying to a program an Atmega328P-AU (TQFP32 package) with the arduino bootloader, using my arduino duemilanove as an avrisp, and avrdude. But, everytime I try to read in the chip throught windows command prompt and avrdude, I get an error saying the device signature is incorrect. I have been able to read in a regular Atmega328p chip (PDIP28 package) just fine in the past. Does the TQFP chip have a different device signature? If so, how would I program it with the bootloader?
    thanks,
    Carlos
    maybe someone has to sell USBTinyISP ?Sent message to my private.
    thanks
    BR/Ugnius
  • wb8nbs
    wb8nbs over 15 years ago in reply to terryking
    Terry King:
    These RS485 look interesting but appear to use a proprietary cable connected to a proprietary shield? I would be interested in the brick without *any* soldered on connectors. Could then use as part of a hard wired home monitoring node. Could not find a spec sheet on the brick or the chip it uses on the web site.
    This raises the question of, at what point is it worth doing your own printed circuit as opposed to buying a breakout board. I would buy ONE, think about buying FIVE, but do a printed circuit for TEN.
    I had inquired regarding connecting this Devantech SRF02 to an Arduino
    http://www.acroname.com/robotics/parts/R287-SRF02.html
    and you indicated that an option would be to start by soldering on header connectors. In a separate kit I bought I have some of these.
    http://www.o-digital.com/uploads/2179/2187-1/Pin_Header_Connector_Straight_Type_801.jpg
    So, I would break off five of those and put the short sides through the holes (they fit through fine) and then put solder in the hole? That sounds like a good idea. Seems the pins are 1/10 inch apart, but I'm not sure how to find a connector that would fit on, matching those five pins... How might I best find the appropriate sized wired connector? Thanks.
    hi,
    how write  code?,(arduino uno, ATMEGA328P-PUATMEGA328P-PU) I need if analog input <2V then 2,3 pins output high, if input>2V then 4,5 output pins high, if >....., then ....
    Thanks for advance
    Bye
    BR/Ugnius
