Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 69644 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • mark2ain
    mark2ain over 15 years ago
    I am curious about feasibility and costs of setting up a video/thermal image monitoring system at a general aviation airport whose purpose would be to collect data on the length of time jets run their engines while on the ground. This data would be used to help determine the extent of fumes and other emissions. The idea would be to set up enough cameras to see jets where they are parked, note when pilots turn systems on, and track them until takeoff. If anyone knows whether such a system exists already, that would interest me. If not, the question is whether this idea makes sense, how much real estate such a camera can cover, what sort of info gathering hub would be required, how would data be best reviewed, stored and frequency of recycling recording media. Cost is big, of course. I am not a technician but a community member of the commission that advises my city on airport issues. Thanks
  • sciguy14
    sciguy14 over 15 years ago in reply to mark2ain
    Well first off, I can tell you that this is not a problem suited to the arduino.  I would imagine you having dozens of ethernet-enabled cameras all feeding through an intranet into one central server that could do some intense image processing tasks.  This project would be large and expensive, but certainly not impossible.
  • servant74
    servant74 over 15 years ago in reply to mark2ain
    You might consider asking your security system vendor for the Airport, if they have CCVs that are infrared or near-infrared sensative.
    If you have both a visable video feed that goes along with a infrared feed, you could use that to determine which planes it is (by N-number or other identifying information).  If you have good vantage points you could put a system of continuously scanning cameras to cover a lot of area, depending on your airports geometry.
    I am thinking your big cost will come in people to review the footage, or find some kind of software that can scan the images might be expensive, but it might be cheaper than a couple of full time people just to scan the images.
    Let us know how it goes!
  • mark2ain
    mark2ain over 15 years ago in reply to servant74
    Thanks for the replies. I was just referred to this site by a possible camera supplier but am not certain how to use it properly.  If there is someone else who might be more expert at specifying what this project would involve, along with ballpark costs -- either an expert or supplier -- I'd love to be in touch. I have been tasked as a committee of one by the commission I sit on to come back with some estimates, but I'm in no position to actually attempt to design such a system myself.
    When reading the spec for an LED matrix, Newark lists the luminosity. Is this the luminosity of each of the bulbs individually, or the luminosity of the entire matrix?
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    I'm not positive, but if I had to guess, I say it's for each LED.  Do you have a link?
  • R_Phoenix
    R_Phoenix over 15 years ago in reply to servant74
    @Servant74
    Do you work for or with the Airport? Something that might save you a ton of money is the fact that each Airport should have a record as to when each jet starts it's engines, when it taxi's and when the jet took off as each of these things require permission from the Tower.
    Ok, I've got a question about the capibilities of Arduino.  I'm in the planning stage to build a USB racing steering wheel controller.  It requires precision and reactive inputs & outputs to a control feedback system.  My concern about Arduino being used as the controller came in after watching how servo motors react to the output from the Arduino after the input data from a POT is taken.  There seems to be a very small delay be the change in data from the POT and the response by the servo motor.  If I use Arduino as a controller can I expect this type of delay or is this an issue with the servo motor response?
    Reference Video:
    http://www.youtube.com/watch?v=FKj9jJgj8Pc
    Thanks for any response or direction
  • sciguy14
    If you really really need fast response times, you should look into programming an atmega in C directly using an ICSP (In circuit serial programmer).  An atmel programmed in C can swith outputs much faster than an arduino due to the nature of the simplified arduino language.  Alternatively, you can try implementing C code directly on an arduino using this tutorial: http://arduino.cc/en/Hacking/Programmer
    hello sir i gave simultaneous input through usb and vin. board went off. what could have happened and how to rectify it..?
