    • Avnet Boards Community
Arduino Forum Hall Effect Sensor Advice
  • Subscribers 391 subscribers
  • Views 185 views
rahimmuh3
rahimmuh3 over 9 years ago
Hi! My name is Rahim Saadiq, and I am a Mechanical Engineering student at South Mountain Community College. I am currently taking a Engineering Special Projects class where my team and myself require a high sensitivity Hall Effect sensor that is able to read the Earth's magnetic field strength between -1 and +1 gauss, maybe even as low as 0.2 gauss. Right now, it seems that we can not find such a sensor very easily...
Also, the sensor should be able to interface with Arduino of course...
Any help or advice toward finding such a sensor will be appreciated.
Thank you.
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago
    Did a quick google search for Magnetic Sensor I2C and found this little puppy
    it supports 4 Gauss full scale and is 16 bit so easily resolves 0.2 Gaus
    http://www.st.com/web/en/resource/technical/document/datasheet/DM00075867.pdf
    you can get a board for about 5$ https://www.pololu.com/product/2737
    there are Arduino libraries / code available https://github.com/pololu/lis3mdl-arduino   for example
    even a shared board with way more ability like pressure etc https://www.oshpark.com/shared_projects/xPM4PPp9
